GSC Power Division Cams - Installed and turning!!
Old Mar 31, 2005 | 11:33 PM
  #31
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
these cams will do it all street to strip , road racing to 10 second 1/4 miles.... bump for Greg!
Old Apr 1, 2005 | 08:31 AM
  #32
turboex's Avatar
Originally Posted by AdamsssEvo
Hey turboex,
Was you tuned at topspeed by Al awhile back? If so did you have a friend with some video
footage of me driving.
yeah bud thats me, my brother was the one taping and he put it all on a cd. I post it up asap. I just have to ge to my moms house to pick it up. Hey man are you running any valve train stuff with you 262/272 setup? Your ride was sweet. Ill try getting my mom to mail me the cd, as my brother is out at sea. lates
Old Apr 1, 2005 | 09:45 AM
  #33
AdamsssEvo's Avatar
I have stock valve train. Al maybe going to topspeed again on May 7. I may get tuned for
some race gas It would be something if I had some Alky by then.
Old Apr 1, 2005 | 10:19 AM
  #34
Aby@MIL.SPEC's Avatar
Originally Posted by EVOTEXAS
I KNOW this setup will make more power than my HKS 264's. It has a bit more pull above 6K. My 264's hit 340 on pump gas at 6500 RPMs and I am certain these will shift the power up a little towards 7k - 7.2K and give a little bump in HP and possibly even more torque due to the retention of the 264 exhaust cam
Does your new cam set-up feel the same as the 264's below 6k?
I currently have 264's & I am on the fence whether or not to go with the 272 int??
I am not sure the reward is worth the hassle for obtaining a 272 int cam......
Still have yet to see a dyno chart 264/264 vs 272I/264E compare anywhere......
Old Apr 1, 2005 | 01:01 PM
  #35
turboex's Avatar
Im totally in the same boat, cant decide. I what to see 272-272 vs 264-272. To bad a shop wont run some numbers. I wan the most power but no stalling issues. And i dont want to have to get cam gear.
Old Apr 1, 2005 | 06:23 PM
  #36
EVO32570's Avatar
You said a flashed ECU. Does Battleground flash or did you get a thru the mail?? Just wondering because I think Im gonna make a trip to GA soon.
Old Apr 2, 2005 | 06:16 PM
  #37
j8's Avatar
j8
EVOTEXAS,
What kind of numbers did you put down today? I am just assuming you got your tune up in Dallas done.
Old Apr 2, 2005 | 06:19 PM
  #38
tke_413's Avatar
I think he put down mid 350's on pump gas...his car in an animal for what's done to it. I had the GSC 264/264's installed and gained 46.9WHP and 32.6TQ...these cams are awesome.
Old Apr 2, 2005 | 06:30 PM
  #39
j8's Avatar
j8
Thanks for the answer. I just did the same set-up and was really curious. Regretfully, I had to do the mail since I could not make the trip up.
Old Apr 2, 2005 | 06:33 PM
  #40
nothere's Avatar
tke 413,
I just got a set of gsc's 264s(not in yet), everything else being equal you got 46.9 hp out of the cams themselves?
Old Apr 2, 2005 | 06:38 PM
  #41
tke_413's Avatar
Originally Posted by nothere
tke 413,
The ONLY other things I've added since the last dyno were the Greddy turbo timer,oil-catch can and a mini battery. None one of those do a thing for performance, and the car was already flashed. Joey installed the cams, and then Mark flashed it again the tuned it...going from 296.9 to 342.8. It was at 345 before he turned the boost down a little.
Old Apr 2, 2005 | 06:44 PM
  #42
04AWDTURBOEVO's Avatar
Originally Posted by GregGSC
272/272 power-division cams with stock turbo and stock block. Stock ECU reflash
The power (HP) starts to drop way before 6000 rpms! That is terrible for after market cams. Cams like that should pull strong to the top. Who cares if it is got 400 hp. The power is droping and that is an indication there is something wrong with the set up! Is it the Cams or the Tuning?
Why would you like Cams that can't make power above 6K? Am I the only one that sees this?
Old Apr 2, 2005 | 07:13 PM
  #43
bpclements's Avatar
The power is falling off like that because the turbo can't hold the boost in the higher rpms. The stock turbo will peak between 26-28psi in the midrange and then quickly fall off to 21-22psi in the higher rpm range. This is why the midrange is so strong. With a bigger turbo that will hold the boost you would see the power continue to climb.
Old Apr 3, 2005 | 10:05 AM
  #44
EVOTEXAS's Avatar
Yes from what I understand I put down mid 350s with these cams and that was with 3-4 gallons of 89 octane mixed in with a full tank of 93 (sorry Mark) for a safe tune. I guess that means there is more there. Hehe. So I am super happy with the GSC 72/64 setup. Amazing cams, amazing vendor. I will post the graph as soon as I get it. I was in San Antonio this weekend and joeycoates took my car up to the dyno shop. Thanks Joey!! And thanks Mark, too!!
GSC =
Old Apr 3, 2005 | 04:10 PM
  #45
GBEvo's Avatar
Great numbers. I bet it pulls like a beast!
