Plug-n-Play O2 sim ???
Old Mar 2, 2005 | 03:18 PM
stvbreal's Avatar
Question Plug-n-Play O2 sim ???
I've seen different O2 sims and tricks to avoid the SES light. What I was wondering is why hasn't someone come up with a Plug-n-Play unit?
The O2 sensor connects to a plug that is behind the rubber stoper. Why not make something that allows you to remove your O2 sensor from the exhaust, unplug the O2 sensor from the cars wiring, and plug this sim in? Then use an oil drain plug, something, to put in place of the O2 sensor that used to be in your exhaust pipe. Just a thought. I'd buy it. Maybe there's already something like this., don't know.
Old Mar 2, 2005 | 04:01 PM
RallySport Direct's Avatar
Silver Sponsor
This is very hard to do. All the current O2 sims that we use still require you to keep it inside the exhaust stream. Without the sensor heated up it will throw different codes then PO420 it will throw some like O2 sensor slow to respond and such. The perrin is the only one that we have used without any problems. It can be installed inside the car no jack required and is simple to install. A plug and play would be nice but with modern ECUs I don't think that it will happen.
Ben
Old Mar 2, 2005 | 06:08 PM
bishiboy's Avatar
I used to be on the hunt for the elusive O2 sim. Then I discovered, from another evom member, the great use of spark plug anti-foulers.
They are on the HELP isle at Pep Boys.
Get the two pack, deep, 18mm version.
Drill out one of them with a 1/2" drill (easy).
Screw the drilled one into the un-drilled one.
Remove your rear O2 sensor, screw in the anti-foulers, screw the O2 sensor into the anti foulers. Done.
There is a small hole in the anti-fouler that lets in a little exhaust, but not enough to let the sensor know the cat is gone.
I've had this in for over 9k miles with no SES (CEL).
Total cost $4.95
Old Mar 3, 2005 | 07:01 AM
Deepseadiver's Avatar
great tip/trick I wish I had knowen about that a year ago.
Old Mar 5, 2005 | 09:10 PM
Tim@AMSperformance's Avatar
Call AMS I believe they have a plug and play unit for 03-04 evos. Im pretty sure the 05's have a different plug
Old Mar 5, 2005 | 09:27 PM
evo81's Avatar
Total cost $4.95
this works very well.no light for over 2500 miles
Old Mar 6, 2005 | 05:38 PM
EricJ@AMS's Avatar
The '05s definatly have a different plug. I believe the '04s have the newer plug too. If thats the case, unfortunatly the unit we have only works for '03s.
Old Mar 6, 2005 | 07:48 PM
bishiboy's Avatar
Guess you'll have to spend less money and get the lower technology solution that works; anti-foulers!
Old Mar 7, 2005 | 06:59 AM
b18flip's Avatar
awesome tip, i'll have to try that
Old Mar 7, 2005 | 07:14 AM
Zeus's Avatar
Anti-foulers
aamoedo
Jul 31, 2016 10:00 AM
Peter10654
Dec 13, 2009 10:20 AM
RelentlessEVO
AEM EMS
Aug 12, 2008 01:47 PM
tweakdsm
Jul 10, 2004 02:46 PM
JasonS
Jan 17, 2004 04:15 PM
