Lets Talk Flywheels
Old Mar 4, 2005 | 11:25 AM
93civEJ1's Avatar
Originally Posted by mndeerslayer
Ditto. A resurface is only $80 bucks anyways.
haha then you got ripped off......Its around 30 here. No one here is talking about money issues. The issue is downtime!.
Old Mar 4, 2005 | 11:52 AM
'ringmeister's Avatar
Originally Posted by bolsen
I plan on keeping the stock flywheel. I can't justify the 400$+ for a 4lbs reduction. (Just my .02)
As for the resurface, I'll decide that when I see it.
-the level of increased acceleration by reducing weight at the flywheel is affected by gear multiplication. so for example, and these are very rough guesstimates, a light weight flywheel will make you care accelerate like it is 200 lbs lighter in 1st gear, a 100 lbs lighter in 2nd, etc. in otherwords it is most noticable in 1st and 2nd gears. on the other hand, for launching a heavy flywheel can help you by storing inertia so you don't bog.
Old Mar 4, 2005 | 01:22 PM
Taimur's Avatar
Originally Posted by 93civEJ1
, and a few occasional notchy shifts. Im hoping the new clutch will help straighten this out.
For me getting a counter weight shift knob has alleviated the notchy shifting feeling.
Old Mar 4, 2005 | 06:02 PM
robert5995's Avatar
EJ1 - If your favorite machine shop thinks the friction surface of your flywheel looks questionable, have them grind off .010 or .020. It'll work just fine, and, as others have posted, cast iron dissipates heat better than steels. Just don't beat it up, and you'll be fine. It wasn't designed for repeated "launches".
Old Mar 5, 2005 | 07:46 AM
superz's Avatar
Our stock flywheel is not cast iron like most are, instead it looks to be some form of steel, what kind exactly I dont know.
Old Mar 5, 2005 | 07:50 AM
93civEJ1's Avatar
I dont know, but I have decided to keep the flywheel stock, just so it keeps everything in balance. As for the resurfacing, I guess that will depend on how the wheel looks when everything is apart.
Old Mar 15, 2005 | 10:41 PM
ProStreetOnline's Avatar
We have not had any warping or noise issues with our chromoly forged Pro Street flywheels. We are selling our 10.45lb flywheels with ACT Heavy Duty Clutch kits for $729.99.
If you need just the flywheel, it's $319 shipped.
Duby
Feb 1, 2011 10:41 AM
Nastynine
32
Dec 2, 2010 10:33 PM
TTP Engineering
50
May 12, 2009 12:29 PM
sykou
Lancer Tranny/Drivetrain Tech
Aug 12, 2008 09:45 PM
VRamirez2004
Apr 20, 2006 01:51 PM
