Super charger/ Turbo pics
Originally Posted by xepyt
Holset HX-50? Holy jebus, my bro-in-law runs a turbo off of that series on his dodge 3500 dually.
Originally Posted by gestalt
FWIW. I would consider mounting an small electric fan on the underside of the hood to suck out all of those hot gasses. That engine compartment is going to be like an oven.
Originally Posted by propellerhead
I'm keeping an open mind on this. This concept was tried 20 years ago when Lancia campaigned the Delta S4 in Group B. From what I understand it was extremely complex and pretty difficult to make the transition from supercharger to turbocharger.
Then again, there's another part of me that suspects this is an elaborate set up for April Fool's Day...
Originally Posted by koolade9
if you go with the "robi spec" cf body kit...that car would be the equvalent of someone geeked out on steroids and trimspa...
keep up the good work... sp engineering says it best, "innovator, not imitator"
in the test, they're both using a 2" pulley, it's illustrating how much more efficient the twin screw is. With the same # of rotations, the twin screw is making 3 more psi, and still making 72 more hp... that's freakin amazing
Originally Posted by chuntington101
thats ace! very nice to see some one insane enough and with thwe money to do it as i hae been wiating to see one. just a few questions. what is the dissplacement of the blower? as how are you rigging up the release valve (between blower and turbo) to provent the blower being a restriction? a few huys over here in the UK have done it on some fords and they wehre using an electric motor to open a valve. it would open at a fixed inlet manifold preusre and allow the turbo to take control of the boost once up and running!
also what boost will you be running from the blower? 1 bar ish? and what presure are you animg for with the turbo, 45psi????
great set up and please keep us posted on how its going.
thanks Chris.
thanks Chris.
Originally Posted by smittyinva
Is this a Quaiffe transmission? I just got a quote from them and almost **** myself.
2.3ltr evo with a turbo and supercharger..............and dog box and sequentical shift!!!!!
dam this car is getting better and better. you could stick a cage in it and some gravel tires on there and race it up piule peak and this rate
thanks Chris.
thanks Chris.
This is gonna be really intresting to follow,hope you can keep us updated with the build,have a look at this "Lancia Delta S4" which have the compressor/turbo setup (original)
http://www.zavodydovrchu.cz/vrchy/re...3_ianiello.mpg
God luck with the build guys.
Wow, this is pretty amazing. The quality of that manifold is par with a factory backed pro import car. The problem is you may not have a class to run in with that two power-adder setup. You should contact the guy who had a custom quaiffe drivetrain built (RNR built the car) because I doubt your going to have an easy time keeping the vehicle reliable if you really plan on driving it on the street.
