Tomei Blow Off Valve
Old Mar 17, 2005 | 07:19 PM
pmysko's Avatar
anybody used the Tomei Blow Off Valve? any positive or negative results? http://www.tomei-p.co.jp/_2003web-ca...bo_outlet.html
Old Mar 17, 2005 | 07:58 PM
Mike@Forge's Avatar
I don't presume to know anything about Tomei at all as comapny, and this is only my personal opinion and not the official position of Forge, but....
... it looks like a factory valve made from stamped aluminum.
The only possible difference would be a different ( ie: stiffer) spring rate, which isn't listed.
Anyone know?
Old Mar 17, 2005 | 08:01 PM
evolife04's Avatar
i have the plastic one works great
Old Mar 18, 2005 | 06:17 AM
evo 8 ya's Avatar
APS is great. awesome drivablity.
Old Mar 18, 2005 | 01:26 PM
rsboy's Avatar
Results after reading the description: headache.
Old Mar 18, 2005 | 03:31 PM
self.one's Avatar
tomei makes very high quality engine parts, specializing mostly in internals (pistons, rods, cranks, etc.)... they just recently came into the u.s. a couple of years ago (group5 motorsports and aebs in san diego are their u.s. distributors), but they have been one of the top manufacturers in japan for sometime now, with companies like o.s. giken, arc, jun, hks, apex being its rivals as far as parts and reputation go....
as far as the bov, it does look like a stock stamped oem piece, but i'd have to agree with Mike that it probably does have a stiffer spring inside.... either way, you really can't go wrong with tomei, and you truly do get what you pay for...hope this helps...
eddie...
Old Mar 18, 2005 | 11:51 PM
pmysko's Avatar
yes thanks so much, so which one you recommend?
Old Mar 19, 2005 | 01:46 AM
self.one's Avatar
i personally have the hks ssq ver 2 with the polished charge pipe.... its vented to the atmosphere and i have had no stalling or stumbling issues at all (although i do have the hks eids as well), and it holds boost well...
to each his own as, there are too many personal factors with bov's to really recommend one... but i have the hks and its perfect...
eddie...
Old Mar 19, 2005 | 06:45 AM
pmysko's Avatar
thanks so much for your help
Old Mar 19, 2005 | 05:28 PM
self.one's Avatar
no problem...
rgowani
30
Jun 4, 2016 01:43 PM
Touge Factory
41
May 12, 2011 12:31 PM
aka.ralliart15
Sep 16, 2009 01:19 PM
Touge Factory
15
Mar 2, 2009 04:04 PM
Scottr126
Dec 23, 2008 10:57 PM
