stock boost?
Now i know the stock boost on an evo is 19 pounds, but i had to take my recirculator off my BOV to make it fit on better for the time being and i feel a TOTAL drop in my boost...i have the boost gauge that comes with RS's and now its only boosting to in between .5 and 1 bar... is that too low? i could have sworn it was boosting almost to 1.5 when it was stock...
thanks guys
Sean
thanks guys
Sean
yeah i currently have a greddy type-s BOV, so im prolly getting about 10 pounds? now if i start recirculating will it go back up? or will i have to put a boost controller on as well to get back up to the 19?
u have a boost leak, try to reinstall everything the way it was before u had the problem .
btw mitsu stock gauge sucks big time.
and why did uchange your stock bypass valve? for the noise?
if u are stock or are not planning to go above 25psi the MR bypass valve is your best replacemnt for the stock unit.
I like how boost problem ALWAYS = boost leak on EvoM
Are the lines still hooked up to the boost solenoid? Or do you have a boost controller? The solenoid could have a problem, mine did, and after 5 hours of looking for leaks, I hated the whole community that told me about checking for leaks and were SOOOO sure it was a boost leak... took 3 seconds to fix with a boost controller!
I have a stock 05 and i boost at 1.5 bar constantly...thats on a defi- link gauge. I cant figure out why people keep changing their BOVs to get that stupid sound...if you have the greddy recirculate it, it will probably fix a few problems. why increase boost with a controller just to compensate for the air you waste when you vent to atom???
just a thought.
just a thought.
Originally Posted by maeisforlovers
... but i had to take my recirculator off my BOV to make it fit on better for the time being...
Sorry to be blunt but,......non-recirculate = gey
......period. Why fool your ecu? It already assumes that air will be there. The extra fuel that the ecu adds will put your 30k$ car in a crappy state of "un-tune".
Don't mess with it unless your using full standalone fuel management or a maft blowthrough setup. Otherwise recirculate it.
nspyr
26
Jun 20, 2017 02:08 AM
