acd service question
Old Mar 29, 2005 | 09:45 AM
agolgan's Avatar
The other day I noticed the atf in the acd resivor was low when driving home so I stopped at advance to pick up atf. Wasn't sure which kind to get, so I decided to wait till I could go by dealer. That night on the way home flordia had massive thunderstorms so I put it in snow mode thinking this is probally as close as this evo is ever going to get. Got home and the resivor was full. Noticed the amount in resivor changes with mode. Should it be checked in tarmac, gravel or snow? Also would any atf III be ok? I would hate to mess up this diff, cause I'm sure its expensive. If anyone can help thanks in advance.
thanks
anthony
Old Mar 29, 2005 | 11:33 AM
evo 8 ya's Avatar
was the fluid higher or lower when you checked it in "snow" mode
Old Mar 29, 2005 | 07:44 PM
agolgan's Avatar
It was higher in snow. I going to test it tomorrow and see how much it changes when I drive it in each mode. I'll post what happens.
Old Mar 29, 2005 | 07:48 PM
lexxtek's Avatar
i notice mine is the same way level is up and down, and fluid wise use only diamond atf from mitsu or else most likely other fluid will ****ed it up...
Old Mar 31, 2005 | 08:39 AM
agolgan's Avatar
ok drove my car yesterday and in tarmac the fluid was right below where the half way mark on the resivor (where it looks like the two halves were combined), well below the min mark. In gravel it was right above that mark not much above it though. In snow mode it was a hair above the max mark. I called misu all mechanics where at lunch. So I'll call agian and I will post after I get an anwser from them.
SOUNDWAVE333
Nov 10, 2013 06:24 AM
rickyart23
Jun 6, 2008 09:23 PM
SmokinJoe
Nov 13, 2005 07:52 PM
EVO_GUY
12
Feb 19, 2005 12:44 AM
illizit
Lancer Troubleshooting
Aug 31, 2003 10:03 PM
