My EVO is hurt
Old Apr 1, 2005 | 12:33 PM
MuslimEvoFreak's Avatar
Originally Posted by PSIbabi21
I'm with him, whos with them.
Im with him too. ^^
Old Apr 1, 2005 | 01:03 PM
LateSleeper's Avatar
Originally Posted by J Dog
Okay I checked the o ring that came on the Walbro pump (That's the black o ring on the topside of the pump when it's sitting upright in the assembly???). It's sitting nice and tight in the assembly right now and I'm still having the same issues. Right now I'm switching it out with the stock pump to see if it's the pump itself. Thanks guys for your help so far.
Not that O ring. We talking about the one that inside the black grounding connector. It's on the opposite side of the float. There's a black connector that you pop off. Follow the black wire. Inside of that is an o ring that needs to be sealed correctly. You'll know what we are talking about when you pull the black connector off and look inside.
I wish I had a pic.
Old Apr 1, 2005 | 01:25 PM
EVO8LTW's Avatar
You checked the lower hose connections on the FMIC too?
Old Apr 1, 2005 | 03:30 PM
J Dog's Avatar
I wish I had a pic.
Thanks for the explanation and advice. I checked that O ring and everything is as it should be. I replaced it the fuel pump with the stocker and it wouldn't ever start up. So I put back the Walbro and it started up. There is no more rough idle and it runs but once I get right around 3000 rpms and 3500 rpms the car starts to buck and sounds like it misfires. Bucking almost feels like boost cut but it repeats. As long as I stay under 3000 rpms they car runs like it should but after that all h*ll breaks loose.
Old Apr 1, 2005 | 07:43 PM
J Dog's Avatar
It's fixed and she's running!!! I can't tell you how happy I am right now. The problem did lie with the fuel pump like everyone had said. I feel absolutely stupid now that I realized what the problem was. I had forgotten the plastic spacer from the OEM pump and had not put it on the Walbro with the grommet. Anywho, thanks for everyone's help because it did keep me looking at it to figure out the problem. I am freakin glad that this site exists, otherwise I would have been totally clueless.
It took reading through another hundred posts to realize what I had been missing.
Old Apr 1, 2005 | 07:55 PM
WHTEVO's Avatar
sorry for the post. saw you got it fixed.
Old Apr 3, 2005 | 01:18 AM
fareastkorean's Avatar
what do u guys mean the plastic spacer, does it stick on the stock pump? Also I have the same problem you had ever since I got rear ended. This shop supposedly put a new pump and plugs in my car but car still runs the same. I dont even think they did ****. Anywho, I might have time tomorrow, Ima check out the pump once again and see if I find spacer piece, I didnt see it on my walboro, maybe its still on the stock pump? When I checked out the stock pump, it was just the pump, i donno what spacer piece you guysa re talkin bout. Anybody got a picture?
Old Apr 3, 2005 | 01:31 AM
DynoFlash's Avatar
A LOT of people have made the same simple mistake - as soon as you hit a nice sized bump the pump falls down and pressure is leaking back into the tank - not enough fuel supply to make boost. Glad you got it sorted and enjoy!
Old Apr 3, 2005 | 11:36 AM
J Dog's Avatar
I pm'd you with a link to some pics that helped me figure out my problem. Good luck.
Old Apr 3, 2005 | 11:38 AM
J Dog's Avatar
Me too! I left a message on your phone the day I broke down so don't worry about calling back. My name was Jeff btw. Also the flash is awesome I can definitely feel the difference.
Old Apr 3, 2005 | 01:45 PM
WOOOOOOOOOOOOOOOOOOOT I Love you guys who posted this info. Checked the stock pump and it had this white spacer piece. The shop that put the new pump in said my old pump was messed up, and they used this stupid black rubber piece which didnt do shiet. So I used both that rubber piece and the spacer, and it wasnt even coming loose again because it was so tight. MAN I punched the car for the first time in 2 months, now with the new dyno flash I got, Im telling you Al is the best, that **** sounds aggressive and my car is kicking *** once again!! Only thing, the coupler that fits into the upper ic pipe to the throttle body keeps popping off, I needa get a new coupler for that and some t bolt clamps that HELIX Has yet to SEND ME!! Thanks for all the help, of this forum I can drive my car like an evo AGAIN!!!!! WOOOOOOOOOOOOOOOOOOT
Old Apr 3, 2005 | 03:58 PM
J Dog's Avatar
Glad my stupidness (not even sure that is a word) could help you out?
Old Apr 4, 2005 | 02:52 PM
Got some t bolt clamps and put them over the upper ic pipe. Oh my fawking god, now the car screams like a bat out of hell, the car is faster than it was before the accident and drives even better! That dynoflash and new exhaust and t clamps improved my car a %100. I love my car once again, took 2 months to get it straight again after getting my *** rear ended. But I'm glad its finally back, thanks to all of my friends and you evom guru's out there 8- ) Al thanks for the flash, you kick major ***!
lance6161
Jul 20, 2025 05:19 PM
mdosu
Aug 27, 2014 08:32 PM
livelyjay
Nov 11, 2013 03:58 PM
tehSteve
Dec 30, 2012 02:01 AM
Ginglingston11
Dec 4, 2011 08:40 PM
