Bov Help...
Old Apr 5, 2005 | 05:05 AM
DARKMETHOD's Avatar
Bov Help...
sup fellas,
well i just installed my bushur up/ic piping with a HKS ss bov and recirculation kit. my evo is fine on a straight away but when it comes to a turn or slow down to 2nd gear i guess it boggles alittle, it stopped on me 2 times this mourning where i had to restart the car as i was rolling.
i looked for write ups to help me but seems this link i found will not come up for me,
http://www.serioussolutions.com/evo/hks_ssqv.htm
i found it here.
https://www.evolutionm.net/forums/sh...ad.php?t=75619
so i was wondering if anyone could lend me some insight to adjusting this problem.
thanks guys .
Old Apr 5, 2005 | 05:12 AM
Silvercar's Avatar
Originally Posted by DARKMETHOD
sup fellas,
i found it here.
thanks guys .
Welcome to my world. I have a 03 and it hates BOV the VTA I went thru 3 Bov s and finally found one my car wont have a fit with. My only sergestion s would bo to recerc it or EIDS it. (HKS Electronic Idel stabalizer) Or go with the APS DD BOv my car loves it it VTA at hi boost and low boost it vents to the Intake.
Old Apr 5, 2005 | 05:25 AM
DARKMETHOD's Avatar
are you serious! see i have always loved the hks bov, i have it on my supra. i just didn't think i would have this problem. i mean i got the recirc kit so i wouldn't have this problem, but i did find a thread here-
https://www.evolutionm.net/forums/sh...d.php?t=131530
i found this little bit of info-
Originally Posted by Coolguy949
I've installed about 15 HKS BOVs on evos and not one problem recirculating. There a couple things you need to buy to make it work with the evo. First, you need to buy a 1 inch radiator hose (about 1 inch long too) because the recirc nozzle isnt wide enough for the hose clamp to fit around it in the dump hole on the turbo inlet pipe. Next, you need to buy about 4 inches of vacuum hose since HKS doesnt include the smaller hose (stock is too big) and they just include the big to small adapter.
i wonder if this would help me?
Old Apr 5, 2005 | 05:30 AM
Silvercar's Avatar
Not sure I run around with a bunch of evo s they ALL have HKS Bov VTAing NO problems what so ever but mine on the other hand is very finiky. So ya STOCK or APS the Blitz no hks no ya it sucks!!! Oh well found one problems go bye bye.
Everyone of these cars reacts differnt tho good luck with yours.
Old Apr 5, 2005 | 07:36 AM
DARKMETHOD's Avatar
I guess i will try the hose thing, seems cheaper for right now. but this really sux man. i thought it was going to be alright, but i just gotta fix that little thing and it would be perfect.
on here-Next, you need to buy about 4 inches of vacuum hose since HKS doesnt include the smaller hose (stock is too big) and they just include the big to small adapter.
i wonder what size for the vacuum hose?
Old Apr 5, 2005 | 07:55 AM
si_eater's Avatar
im one of the lucky ones where my car is real tempermantal i have the hks ssqv
its recirced and ive tried the eids and still nothing, i still have the same problem
idle drop when coming to stop, or egage clutch at a certain speed (PITA)
Old Apr 5, 2005 | 07:57 AM
PSIbabi21's Avatar
sup fellas,
i found it here.
thanks guys .
by "sup fellas" im sure you meant fellas and laides right?!?! haha!
Anyways, I installed the hks ssq with the recirc on my evo and everytime i was rolling and pushed the clutch in my rpm would drop then bounce around and stall....IT SUCKED...so i took it off and now i have a type-s on there...seems to work a little better, i've been told to take out the smaller of the two springs and it will completly eliminate the problem....if you really like your HKS that much buy the kit for it ^^^^mentioned in a post above for like 70 bucks, and that will solve your problem!! Otherwise you could always sell it, loose your ***, and then have to buy a diff valve and rig that one to work!!
~just a suggestion!
~meliss
Old Apr 5, 2005 | 08:08 AM
si_eater's Avatar
^^^^^^ she has a point, thats why i just stopped bi*hin learned to drive with it someone said it wont hurt it, just until i get my blowthrough maf
Old Apr 5, 2005 | 08:13 AM
PSIbabi21's Avatar
yeah if you dont plan on fixing the problem it's more so learning how to drive with it, dont clutch your car at high rpms always get really low in the gear then clutch it at like 2grand and i've damn near concerred (spelled?) the problem, then again there are those f'n idiots who are slamming on their breaks for no reason and you have to clutch it and downshift, sometimes it will still stall in certain situations. But my car only stalls once a night if even that!
So spend a little more and fix it, or learn to deal with it!
~meliss
Old Apr 5, 2005 | 08:21 AM
si_eater's Avatar
~meliss
well since you know so much about it how would you fix it, ive tried almost everything i could think of, ive recirced, eids, tune down, tune up(afcII settings) on my first one i messed with the screw on the back, and nothing, and just in case i dont press the clutch at high rpms even when im in a parking lot looking for a spot it happens, like i said if you have any suggetions by all means let me know im not an expert i just have tried what i know
Old Apr 5, 2005 | 08:35 AM
evo 8 ya's Avatar
^^ APS makes a great BOV.
Old Apr 5, 2005 | 08:48 AM
PSIbabi21's Avatar
If you have bought the EIDS kit, that should have fixed it, otherwise check all your vaccume lines?! You may have a leak somewhere? Also who tuned your afc?? that might be the reasoning ....the car may run lean at lower rpms or your mass air flow sensor could be causing the problem if there was some sort of leak and not enough air was being recirced....otherwise I would say try a diff valve, I had my HKS on and took it off right afterward, it was recirced, but i still had constant stalls....I never spent the money to buy the eids kit, i just sold it and bought a type-s did the single spring mod and now she runs cherry!!
I would say the eids kit would be your last resort, so check your lines, then if it still gives you problems I'd reccomend selling the HKS and buying a diff. valve that will work.
~meliss
Old Apr 5, 2005 | 09:30 AM
DARKMETHOD's Avatar
PSIBABI- ofcourse (fellas) also stands for ladies also in our community .
thanks, i will try the hose's first. like i said it's not that big but just second gear coming to a stop sometimes (actually it happen twice) maybe a small leak? this EIDS KIT is 70 bucks? what does intell?
Old Apr 5, 2005 | 09:34 AM
PSIbabi21's Avatar
oh well if it's only happend twice i wouldn't really worry about it, if you have a hks on there and it's only stalled twice consider yourself lucky, and just try not to clutch it untill your at 2grand or so, and you should be just fine. If you had a leak it would stall alot more and im sure be very apparent!
Old Apr 5, 2005 | 09:35 AM
krafty's Avatar
There are plenty of threads of the HKS EIDS not working..or even making it worse. You might wanna read up b4 wasting your money
