Low Dyno Numbers
Old Apr 6, 2005 | 09:24 AM
Bom's Evo's Avatar
i just switched out my perrin mbc to a greedy profec b old style. and it works much better than that. holds steadier too. I just used the same hoses into the soleniod.
Old Apr 6, 2005 | 09:28 AM
J Dog's Avatar
Originally Posted by DynoFlash
On a DYNO JET dyno - if you were holding a full 19 psi to red line you could expect 290 - 295 to the wheels
As your tq is MUCH higher thanwhp and your booost is falling down to 17 psi - this is why I recomend you try the Hallman Pro MBC which I am willing to send you for free to test. The Perrin has not worked well in most cars.
1 or 2 psi of boost can make a huge difference in the power levels at 5500 - 6500 rpms
Yeah at 5800rpms I was hitting 236 and again at 5400 rpms I was hitting 238. I believe that's where my boost started to fall.
Old Apr 6, 2005 | 09:29 AM
EVOtagger's Avatar
they would, except they can basically be calibrated to read whatever numbers the end user wants them to...i dyno'd about 20whp less on a dynapack as opposed to a dynojet when i had my jetta
Old Apr 6, 2005 | 09:30 AM
J Dog's Avatar
Originally Posted by MANGOOK
Al that is awesome customer service!! Thumbs up to you for going above and beyond for this gentleman.
Also I have the Hallman Pro on my car and it holds boost solid all the way to redline! You should really try it and see the difference. 4 pounds is a pretty big drop off.
I will try it and that is great customer service!
Old Apr 6, 2005 | 09:36 AM
MANGOOK's Avatar
Good man I hope everything works out for you and you see those numbers go up more.
Old Apr 6, 2005 | 09:53 AM
trevor's Avatar
Originally Posted by evo_08
who told u dynapack was the most accuret?
Probably someone who can spell ACCURATE
Old Apr 6, 2005 | 02:45 PM
jj_008's Avatar
J Dog, You may want to take out your HF cat and make sure it is not plugged. I have seen an EVO w/ a clogged cat and the power loss was pretty good.
Old Apr 6, 2005 | 04:36 PM
J Dog's Avatar
I'll check that out.
vince126
Canadian Forum
24
Dec 3, 2014 12:59 PM
1QYK9
57
Jul 6, 2008 01:35 AM
GsXiNuOFF
May 15, 2008 05:34 AM
hokiruu
Nov 17, 2007 03:27 PM
AfireINSIDE
38
Feb 24, 2006 07:22 AM
