My 10.5 Hotside Install & How-To
Old Feb 23, 2006 | 07:48 PM
  #196
P0411's Avatar
Originally Posted by laakness
You will feel it get tight. Just make it nice and tight and you'll be fine. From stock it's not on their very tight.
So then 30-40" lbs. should be plenty correct??
Old Feb 24, 2006 | 06:29 AM
  #197
laakness's Avatar
Sure, I guess. I just feel it out.
Not everything you do on your car can be defined with exact numbers and a gauranteed way it will work. Just do it and you'll be fine.
Old Mar 1, 2006 | 03:10 PM
  #198
SuperHatch's Avatar
B/C I've had a lot of questions on the parts required to do this...
Exhaust manifold gasket: MR323654
Exhaust manifold washers: MD050076 x2, MD041192 x7
Exhaust manifold nuts: MR224500 x2, MR212302 x7
Turbine housing gasket: MR404547
Exhaust manifold-turbine housing bolt: MN119783 x2
Exhaust manifold-turbine housing washer: MD132933 x9*
Exhaust manifold-turbine housing nut: MD132930 x2
Exhaust manifold-turbine housing stud: MN119784 x2
Turbine housing-O2 housing gasket: MR299686
Turbine housing-O2 housing stud: MR224441 x2
Turbine housing-O2 housing bolt: MD062961 x3
Turbine housing-02 housing nut: MD050073 x2
The stuff in Red is what I recommend, the stuff in black is not needed but wouldn't hurt.
The parts can be purchased at your local dealership or at www.mitsubishiparts.net
- Steve
Old Mar 7, 2006 | 07:43 PM
  #199
gsrmin's Avatar
hey for the bolts, nuts, and stud specs
the thread specs are 1.25 pitch
go to local hard store
those bolts and studs are f@cking expensive
5 bolts, 4 nuts 4 studs = almost 70dollors!!
there is no way iam payin' that!!
Old Mar 7, 2006 | 10:13 PM
  #200
Volunteer's Avatar
Dim-nuts-r expensive up there I spent about $20 at a bolt store, I didn't go back with the studs on the hot-side instead used bolts like some of the others in fact I got those from Auto-Zone in the bolt section by manifold bolts because the bolt store was out. Used hi-temp anti-seize on everything.
Old Mar 8, 2006 | 12:25 AM
  #201
gsrmin's Avatar
do u remember the stud size for the o2 housing side?
was it m10 X 35mm 1.25mm pitch?
Old Mar 8, 2006 | 11:53 AM
  #202
Volunteer's Avatar
That seems right, I just took one of the old one's with me to match it up. They had a key set to match the size. I know I have two spare, but threw away the box. That sounds like the right size from what I remember m10 X 35mm 1.25mm pitch.
Old Mar 14, 2006 | 09:14 AM
  #203
matt55's Avatar
[QUOTE=SuperHatch]This is what it looks like with the turbine housing out, the turbo is held securely in place by the coolant and oil hardlines...
You'll need to attach the O2 housing to the Turbine housing before putting it in the car. You will need to use NEW STUDS where they were on the original hotside. The hotsides do not come with them and even if you are able to get them out of your stock hotside, chances are the threads will be destroyed. So do yourself a favor, order them ahead of time and have new ones ready.
Installation is reverse of disassembly. Total install time... 4 hours for me. Hope this gives some of you DIYer's some confidence to tackle this. Good Luck!!
- Steve [QUOTE=SuperHatch]
Steve
Thanks for the write on we got it done last night in under 4hrs !
D@mn it pulls so much better than the 9.8 hs .
One thing i didnt see in your write up , but I think will help getting the manifold back on is -- Dont put the studs (upper studs that go from the mani to hs) back in the new hotside untill you get the turbo back on and the mani back on , much ezer/more room to get on that way (we had a hard time getting the mani off) . I cant take credit for this it was my pops idea
Old Mar 14, 2006 | 09:52 AM
  #204
SuperHatch's Avatar
Originally Posted by matt55
Steve
That actually what I did when I put it back together, but I forgot to put it in there.... Thanks for the tip though!
Glad it worked out for you... that hotside is a great upgrade.
Old Mar 23, 2006 | 10:23 AM
  #205
Sap12687's Avatar
I ordered my single flapper from Gruppe-s yesterday and it should arrive tomorrow. Should i assume it comes with or without the studs? I plan on reusing my gaskets and i currently have a DNP O2 housing on the car so i hope this will eliminate the problems with the 02 sensor removal. The only thing im worried about it whether or not i will be able to reuse all the bolts. Has anyone reused them all?
Old Mar 23, 2006 | 10:33 AM
  #206
matt55's Avatar
Studs are sold separate about $8 each from
I reused all the bolts and nuts , just not the studs .
Old Mar 23, 2006 | 10:51 AM
  #207
SuperHatch's Avatar
Ditto...
Old Mar 23, 2006 | 10:55 AM
  #208
Sap12687's Avatar
is there anywhere else i can get studs similar to the ones from mitsu.? will mitsu stock them?
Old Mar 23, 2006 | 11:00 AM
  #209
SuperHatch's Avatar
The part numbers for every part you need are listed in this thread, go to www.mitsubishipart.net for them. You might be able to get equivalents at Home Depot, but I wouldn't (material type/quality reasons)
There's not much else we (the forum members) can do for you (or anyone else who asks this same questions 100s of times) Besides buying the stuff for you and mailing it to you, which surely won't happen. Do some of the legwork yourself, your brain might enjoy the exercise....
Old Mar 24, 2006 | 09:06 AM
  #210
fixit's Avatar
Originally Posted by SuperHatch
the 10.5 hotside has a larger cross sectional area where the turbine wheel sits 10.5 cm^2 versus 9.8cm^2, that's the only difference. It has no effect on O2 or DP fitment.
newbie question...
so the diameter of the 9.8 is 3.53cm and the diameter of the 10.5 is 3.65cm -- in other words the outlet is just bored out and additional .12cm (.3")-- right?
