My 10.5 Hotside Install & How-To
Old Feb 20, 2006 | 07:13 AM
  #181
SuperHatch's Avatar
Yes, follow the specs that are ft-lbs. If you have a metric torque wrench, follow the N-m.
Time for install? Less than 3 hours.
You do not need a lift, I havn't had one job on my Evo yet that "needed" a lift, this includes a clutch install. A lift would make some things "easier" though.
- Steve
Old Feb 20, 2006 | 07:30 AM
  #182
laakness's Avatar
It took me about 5-6 hours. I did it in my unheated garage and it was 20 degrees outside, so I had "warm up" breaks. I also had to run to the store for a prybar and some bolts which added about an extra hour to real install time.
Old Feb 20, 2006 | 08:16 AM
  #183
Blue Evo 8's Avatar
- Steve
Thanks steve, I'm gonna do this when all my parts come in...
Old Feb 20, 2006 | 08:37 PM
  #184
KUEvo's Avatar
So does anyone know what to torque the v band clamp to?? Thats the clamp the holds the hotside and oldside together??
Old Feb 20, 2006 | 10:19 PM
  #185
Volunteer's Avatar
Its not really big enough to torque. Use 1/4 inch ratchet, and tighten as tight as you can with it. Its a 10mm nut. I used a second lock nut on top of the original as a back up just to be safe.
Old Feb 21, 2006 | 06:17 AM
  #186
laakness's Avatar
Good suggestion with the second lock nut.
Old Feb 21, 2006 | 08:34 AM
  #187
Volunteer's Avatar
Old Feb 21, 2006 | 08:38 AM
  #188
C6C6CH3vo's Avatar
The torque value is not mentioned in the manual. I snugged it to about 30-40"/lbs and did the same - a second nut.
I still think the hotside was so much easier than cams
Old Feb 21, 2006 | 08:48 AM
  #189
evo4g63awd's Avatar
great job on the instructions
Old Feb 22, 2006 | 07:16 PM
  #190
nbpal4000's Avatar
- Steve
less than 3hrs !!, one of the shops estimated 4 hrs for installing 10.5 hotside!
like 320 bucks.. guess Ill have to look at your procedure hehe
Old Feb 22, 2006 | 07:23 PM
  #191
SuperHatch's Avatar
I can get references from the other members on the site that I've done this for if you'd like....
Old Feb 22, 2006 | 07:33 PM
  #192
nbpal4000's Avatar
nice
im planning to get 10.5 too,
did gasket come with your turbine housing or did you have to buy it seperate?
Old Feb 22, 2006 | 07:37 PM
  #193
Evoryder's Avatar
nice write up and pix!
Old Feb 23, 2006 | 05:59 PM
  #194
P0411's Avatar
Does anyone have any idea if this will be tight enough???
Old Feb 23, 2006 | 06:50 PM
  #195
laakness's Avatar
You will feel it get tight. Just make it nice and tight and you'll be fine. From stock it's not on their very tight.
