My 10.5 Hotside Install & How-To
Old Nov 7, 2008 | 12:24 PM
  #331
AlwaysinBoost's Avatar
its m10 x 1.25 with either a 30 or 40mm length... i forget which.
Old Nov 9, 2008 | 12:08 AM
  #332
stockEvoIX's Avatar
Lightbulb
The 2 studs are "under" the O2 housing, correct? I think only 1 stud is visible.
Also, how do I get the studs out? After I take them out, do I just drill out the hotside and use bolts/nuts? Thanks guys!
Old Nov 9, 2008 | 01:12 AM
  #333
funks's Avatar
some stated just spray the studs with PB Blaster and vice grip it out - lol.
Old Nov 9, 2008 | 04:21 AM
  #334
sparky's Avatar
Originally Posted by stockEvoIX
.... how do I get the studs out? After I take them out, do I just drill out the hotside and use bolts/nuts? Thanks guys!
To remove the studs just thread two nuts down on top of each other. Then as you back them out, they'll back the stud out. Don't drill the internally threaded boltholes out on the hotside either. That would be a no-no!
Old Nov 12, 2008 | 10:25 PM
  #335
stockEvoIX's Avatar
Thanks sparky I guess I'll buy 4 new bolts for the mani and 2 studs and nuts for the hotside.
Old Dec 24, 2008 | 01:23 AM
  #336
stockEvoIX's Avatar
Does anyone have the torque spec for the clamp holding the hotside to the turbo/compressor side?
Old Dec 24, 2008 | 02:09 AM
  #337
javicracer's Avatar
dam
this writing is so helpful for people that is trying to do this task!
Old Dec 24, 2008 | 08:55 AM
  #338
marksae's Avatar
That nut is a little 10mm one. So don't go crazy on torquing that thing or you'll snap the bolt. Just make sure the clamp has fully seated and then snug the nut good.
Old Jan 3, 2009 | 11:46 PM
  #339
ar3nbe's Avatar
Ive done everything so far, and am up to taking the hotside off the compressor housing, but the thing wont budge.
Ive tried hitting it with a screw driver from above, and below, aswell as a chiesel, and nothing. The thing is jamed on hard.
Any tips guys. Im seriously thinking about taking the whole trubo out now.
Old Jan 3, 2009 | 11:53 PM
  #340
whoang40's Avatar
I soaked mine with PB Blaster, then tapped it lightly with a screw driver then it separated.
Old Jan 4, 2009 | 02:10 AM
  #341
ar3nbe's Avatar
ill try letting it soak overnight.
If that dosnt work, its time to drop the coolant and oil, and pull the turbo out
Old Jan 15, 2009 | 04:24 PM
  #342
ar3nbe's Avatar
Did anyone have any issues with the bolt/nut with the vband clamp ?
Long story short, turbo back in, working fine, didnt use the original bolt for the vband because it snaped when i was taking it off. Use a dodgy bolt I had in my garage, vband fell off while I was doing some track work.
Purchased a new vband, and screw from a turbo place that specialies in Evo turbos here in Australia, and now it seems the screw is about 2mm, or so to short.
The lenght of the screw is 35mm, does this seem right ?
I am thinking, ill just got to my bolt shop, buy a m6 high tension bolt, add some threadlocker, and use this
Old Apr 9, 2009 | 07:06 PM
  #343
igo4bmx's Avatar
wow this was easy
i didn't remove the radiator and everything was super easy to remove!
u just need the right tools
breaker bar,
swivel extensions
extensions!
Old May 28, 2009 | 10:25 PM
  #344
mrfred's Avatar
Looks amazingly easy.
Old May 30, 2009 | 09:58 AM
  #345
rlui0514's Avatar
How did you get the manifold off with those two bolts in front???
