The EVO VIII vs EVO IX compressor housing
Old Oct 20, 2005 | 01:42 PM
Chris@nolimitmotors's Avatar
Originally Posted by PeakBoost ken
correct, we noticed that the factory turbo anywhere above 22psi on our 05 car is just a heat pump.
even with our FMIC upgrade, we were still seeing a very hot aircharge (untouchable "cold pipe").
the larger a/r compressor housing should help to keep the temps down under higher boost.
these factory mitsu turbos leave me wanting much much more..
i dont want to hurt anyones feelings, but the top end is just boring even on high boost with the factory turbo.
Ken
Ken you put some Meth in the picture and 30 psi and the pipe is an icebox
Pd1's Avatar
Pd1
Other than the compressor housing, what else is different on this turbo compared to the 05 VIII?
What kind of shaft material?
What kind of compressor wheel material?
Old Oct 20, 2005 | 01:58 PM
trinydex's Avatar
Originally Posted by Jrod@Buschur
The stock EVO 9 turbo does come with the 10.5 Housing. However it has made very little power over the stock 8 turbo. Also it does not hold anymore boost over the stock 8 turbo.
Here is the dyno sheet we did here between the stock 8 and a stock 9.
Jarrod
Buschur Racing Inc.
the fact that it doesn't hold any more boost is due to the taper right? have you guys slapped an mbc on one yet?
Old Oct 20, 2005 | 01:59 PM
trinydex's Avatar
it's all the same if you want a different shaft and wheel material you'll have a few options. hot side, tme stuff, cold side evo9 rs jdm mag wheel.
Old Oct 20, 2005 | 02:16 PM
Pd1's Avatar
Pd1
So, the US-Spec Evo IX turbo doesn't have a TiAL shaft or Mg wheel, right?
Old Oct 20, 2005 | 02:17 PM
trinydex's Avatar
that's right and you cna't put a 20g wheel in the evo9 turbo.
Old Oct 20, 2005 | 02:25 PM
Pd1's Avatar
Pd1
Is there any reason not to get the TiAL shaft and Mg compressor wheel? Any adverse effects whatsoever?
Jaraxle
69
Nov 2, 2021 08:08 AM
ALLBLACK-EVO
Feb 2, 2011 08:23 PM
tim85851
17
Jun 25, 2008 10:18 PM
clip14
18
May 27, 2008 09:37 PM
silex
Sep 25, 2006 06:35 PM
