21G vs. TME turbo
Old May 18, 2005 | 11:08 AM
scherejs's Avatar
Originally Posted by Evo007
What's the price gonna look like on these?
bump for possible price
Old May 18, 2005 | 12:29 PM
trinydex's Avatar
the pricing is already available... and has been available. i'm more interested in what the spool is like in 4th gear....
Old May 18, 2005 | 12:31 PM
Evo007's Avatar
Didn't know if the price was going to change because of the clipping that was done.
Old May 18, 2005 | 12:32 PM
trinydex's Avatar
i think they were recast with the clipping already done... or at least that's what i was under the impression of.
Old May 18, 2005 | 12:37 PM
Evo007's Avatar
ahh..so the prices should be the same. cool.
Old May 18, 2005 | 03:38 PM
Hiboost's Avatar
Looks like spool will be very close to stock turbo levels or within a couple 100 rpm's. Test your car in 3rd, 4th and 5th by starting at 2000 rpm's and checking what RPM you hit 20 PSI with the stock turbo. I also like using 5th gear as it actually gives you a chance to get consistant results since the boost doesn't jump up as fast in taller gears. If Buschur said 2800 in 5th with an exhaust system and intake mods that is right about stock spool. Tuning and alchohol injection would be the only other variables and I'm not sure of his test car's setup.
Old May 18, 2005 | 03:52 PM
LuxuryBroker's Avatar
How soon will you have the Titanium ones available?
Old May 22, 2005 | 04:51 PM
njevo's Avatar
I'm beta testing it for them now. On my 21G from turbochargers.com I made 17hp mid and 12hp on top w/ compressor surge problems...I 'm going to take it off and send it out to get clipped which eliminates the surge. But there selling them now already clipped so you dont have to worry about the surge....I think Buschur is supposed to dyno there car with the 21G mid week and let us know the numbers.
Old May 22, 2005 | 05:22 PM
EvoPanda7's Avatar
will the 264 cams be good enuff for the 21g?
Old May 22, 2005 | 05:23 PM
EvoPanda7's Avatar
and with the 21 g would it be better to get an ams innercooler or a alky kit?
Old May 22, 2005 | 05:26 PM
badlooser's Avatar
Originally Posted by davidbuschur
Finally.
We are now ready to release and sell the new bolt on 21g turbos.
I tested the newest version of this turbo this morning and I am very happy with the results.
Spool up is very close to the stock clipped turbo that was on the car. I am getting over 20 psi by 2800 rpm in 5th gear with the car.
The boost doesn't spike as much as it did with the stock turbo, it is hitting 23 psi and then holds 21 psi to redline. This is much better than the stock turbo which will hit 25 psi on the spike and be down to as low as 16-17 psi by redline.
This turbo unclipped gained 2+ mph in the 1/4 on my RS a few weeks ago. We clipped the turbine wheel to get rid of the compressor surge problems we were having with it.
The turbo has NO surge on my car while accelerating now.
I will get to the track next week and do some testing.
These will only be available clipped as they surge violently without the clipping.
The clipping increases the exhaust flow.
David Buschur
www.buschurracing.com
David:
why dont you put all your turbo options on your web page for all of us Buschur fans to see. You have had the same turbo page for 1 year now.....
Old May 23, 2005 | 02:20 AM
David Buschur's Avatar
Any cam will be fine for this turbo.
The best thing to add with this turbo is OUR FMIC kit if you are adding one with it, the alky kit would also be a good choice as the higher boost that is possible with this turbo could be used.
The prices have stayed the same, the clipping is done by machine, it is not cast into the wheel.
Updating the turbo page is a good idea, but there are more updates coming so we are going to wait.
David Buschur
ravasquez
Apr 14, 2017 09:33 AM
clip14
May 18, 2016 10:57 PM
Richieeeee
Oct 12, 2015 03:18 PM
scott88vr6
52
Apr 28, 2006 09:16 AM
xme
11
May 6, 2005 04:26 AM
