How do you remove the studs from the fly wheel?
Old May 3, 2005 | 11:48 AM
bolsen's Avatar
The studs on the outside of the fly wheel. I thought I read something that there is a certain way to remove these....
Old May 3, 2005 | 03:15 PM
bolsen's Avatar
up
Old May 3, 2005 | 03:30 PM
Compjoc's Avatar
y would i want to remove them?
Old May 3, 2005 | 03:54 PM
bolsen's Avatar
getting it machined
Old May 3, 2005 | 03:58 PM
Curt@MrLed's Avatar
Former Vendor
well when it gets machined they will remove them... if they cant, there a useless shop..you should not be removing them.. leave it to the prof..
Old May 3, 2005 | 04:13 PM
TrinaBabe's Avatar
I assume you mean to remove the flywheel from the car. An impact hammer is the easiest otherwise you can hold the motor with a ratchet I believe... you could also use the cam gear bolts to hold the motor from spinning
Old May 3, 2005 | 05:12 PM
bolsen's Avatar
Thx farmer, I was going to do that, but I wasn't sure if I should or not.
Trina, the fly wheel is off the car already
Old May 3, 2005 | 05:35 PM
TrinaBabe's Avatar
ok, I am used to people that have no idea on what they are doing ask strange questions.
Old May 3, 2005 | 05:39 PM
evo 8 ya's Avatar
Impact gun
Old May 3, 2005 | 05:54 PM
BadazzCR's Avatar
Sometimes if they are very hard to remove you can heat up the area around the studs and then remove them.
Old May 3, 2005 | 05:58 PM
dohcvtec's Avatar
you do not have a stud remover? get one from the local autoparts store for your ratchet, they're like $15
Old May 5, 2005 | 11:56 PM
Curt@MrLed's Avatar
Former Vendor
i think im the only one who know what you were talking about..
Old May 6, 2005 | 08:54 AM
bolsen's Avatar
I took it in, they took em out for me.
poonpower
Oct 22, 2016 06:35 PM
rhd-jon
35
Sep 4, 2011 08:50 AM
Evo_Wanted
21
May 26, 2007 09:23 AM
lanport
Jun 7, 2006 05:34 AM
JT-KGY
Sep 13, 2004 10:49 AM
