MBC or not
Old May 5, 2005 | 07:44 PM
damien ramirez's Avatar
MBC or not
I have a CAI (AEM) and soon will get 3" TBE. I want a flash that controls the boost and holds it till redline. So do you think I still need a MBC, or is that pointless.
Old May 5, 2005 | 08:10 PM
mooreboost's Avatar
Most people use one regardless of the flash. It gives you the control and slightly better spool times.
Old May 5, 2005 | 08:24 PM
ebbeast2005's Avatar
The flash will hold the stock boost to redline. if you have a mbc you can safely run 21 to redline. Its def. worth it. One of the cheapest mods. I have one for sale to if your interested shot me a pm.
Old May 6, 2005 | 04:24 AM
Jakeg97's Avatar
once you go mbc , you wont go back .
unless you need to try and get warrenty work -
Old May 6, 2005 | 10:08 AM
I cut this from another thread but I thought this would pertain to my thread.
Yes, this is true that it doesnt automatically raise boost unless you turn it up. The only point I was making out of all of this is that he doesnt need one if he gets the flash with boost control unless he wants to adjust it often. There is no point in getting the flash with boost at 20psi and then getting an MBC to turn it back down. I just think most people would rather spend money on things that are needed more than buying 2 things that are for the most part doing the same thing.
So in the end, if you want to be able to adjust your boost on a regular basis, then buy the MBC but if you are happy with it set to 19 or 20psi, then just get the flash with boost control.
Quote:
Originally Posted by MYEVO8U
Installing a boost controller doesn't automatically raise the boost level.... You have to adjust the MBC to the desired Psi. I have the Hallman MBC and I could run 12 Psi all day if I wanted to. The boost controller is adjustable and is why they are universal. I have the same MBC on my EVO as I do on My '04 WRX (not Sti). 21Psi on the EVO 16Psi on the WRX.
Old May 6, 2005 | 10:09 AM
this is what I'm getting at.
Old May 7, 2005 | 09:24 PM
in the end mbc would be the best run for most reilable power. if your looking for a little jump over stock then stick with the flash.
Old May 8, 2005 | 01:32 AM
Jakeg97's Avatar
get a hallman
Old May 8, 2005 | 01:41 AM
JDM-Spec.com's Avatar
I have a Hallman on my own Evo, they are perfect:
http://www.jdm-spec.com/turboneeds.html
nikush
Aug 17, 2014 07:38 PM
mscorei
Sep 25, 2007 06:59 AM
Atlmethevo
Aug 13, 2006 09:07 PM
silverevo05
19
Feb 16, 2006 01:49 AM
herbal77
Dec 20, 2004 04:48 PM
