i was just thinking...my friend at school says this happened to him
Old May 11, 2005 | 08:52 PM
neyugn_naut's Avatar
my friend sam says he just put in an intake in his evo and got a reflash, he says that he was driving his evo without flashing for awhile, now he says that with the intake and reflash, his car is still shaking when he speeds up, like between 3-4 rpm. is there a way to fix this? or whats happening? whats wrong with his car?
Old May 11, 2005 | 09:19 PM
bump
Old May 12, 2005 | 05:22 AM
Kronik's Avatar
Couldn't even begin to tell you what is wrong with the car. Whoever did the flash -- I'd take it back to them and have them check it out. Is it just coincidence that he had this problem after the flash?? Maybe..but I'd still go back. Good luck.
Old May 12, 2005 | 07:02 AM
03BREvo8's Avatar
shaking isnt assosiated with and intake and flash... it sounds like a drivetrane problem... maybe one of the differentials...? or there may be a leak somewhere.. causeing the boost not to spool steadily resulting in shaking...
Old May 12, 2005 | 06:44 PM
how would you fix that?
Old May 12, 2005 | 06:55 PM
plokivos's Avatar
it could be your tires not being balanced, your steering rod broken, CV joint cracken, or your axle fallen off of em.
mostly tires not being balanced.
it's either that or you're misfiring or pre igniting or running lean or something in that area.
Old May 12, 2005 | 08:54 PM
timzcat's Avatar
Another second hand fix an evo thread.
If he wants help diagnosing it he can get on here so he can answer questions and provide more information.
Old May 12, 2005 | 08:56 PM
plokivos's Avatar
what's wrong with second hand fix? i was doing that, if you mean second hand fix means you post questions and get some advices from people on diagnosting it.
Old May 12, 2005 | 09:20 PM
timzcat's Avatar
No I am talking about the 'A friend has a problem" threads
He can't possibly provide the necessary information so the problem can be diagnosed.
The guy is not even a member but we are going to spend our time diagnosing his problem when he is too lazy to join?
Old May 12, 2005 | 10:42 PM
Jakeg97's Avatar
tell your friend "he is the problem" and he should give you the evo cause you understand it more
David Buschur
79
Sep 2, 2007 07:05 PM
richie11
Nov 12, 2006 03:08 PM
DragNRacing
Sep 18, 2006 10:32 PM
Chewie4299
May 15, 2006 05:11 AM
MyEvo8
22
Aug 1, 2005 07:45 AM
