CEL Light still ON - HELP
Old May 16, 2005 | 11:53 AM
Bexa20's Avatar
thanks GIsnickers, I think I could apply probably those two if I have to choose because the others look good.
Check the frequency and amplitude of the oxygen sensor (advanced)
Check for a deteriorating / contaminated oxygen sensor, replace if necessary
Old May 16, 2005 | 11:54 AM
Bexa20's Avatar
BTW, how can I check the frequency and amplitude of the oxygen sensor. I have an access to the osciloscope, but what kind of measurements should I be expecting to get ???
Old May 31, 2005 | 09:49 PM
Bexa20's Avatar
Update
This past weekend I tried running the car only on a spark antifouler plugs. I disconnected the O2 simulator completely, and lets antifoulers in. Guess what, still does not work. At this very moment I tried everything I could, and run out of suggestions.
Old Jun 1, 2005 | 05:41 AM
djh's Avatar
djh
If you have a good OBD-II scanner you can watch both O2 sensors at idle. You should see the first sensor oscillate between about 0.1 to 0.9 volts. The second one will also oscillate but in a narrower range about 0.45. If sensor 2 tracks sensor 1 too closely the ECU decides the cat isn't working and sets the (0420?) code. The mechanical fix damps some of the oscillation and usually works well.
Dave
Jakeg97
133
Jul 30, 2021 08:19 AM
PlanoEvo
25
Sep 10, 2007 11:30 AM
SuperStreet2K6
41
Jun 28, 2007 02:07 AM
race17k
24
Feb 7, 2007 05:34 PM
JuancaROD
Feb 21, 2006 01:12 PM
