cooling fan wont shut off
Old May 18, 2005 | 01:29 PM
black evil evo's Avatar
I took it in for the recall on the fan controller because it sayed on and killed my battery. They replaced the contoller and it still stayed on. They said it is the relay so they ordered one and will call when it comes in. i pull the relay out and the other fan fuse and it still stays on. i have to unhook the battery to stop it.
please help
Old May 18, 2005 | 01:35 PM
bigjhoney's Avatar
Yea it was a recall on the relay....had it done to my car also. I dont know what you need help with though..?
Old May 18, 2005 | 01:39 PM
Compjoc's Avatar
The fan shouldn't have current if u pull the relay. U probably pulled the wrong relay.
Old May 18, 2005 | 07:56 PM
replacing the contoller or what ever they did didn't fix the problem. The fan on the front of the radiator still stays on all the time even when the keys are out. It kills my battery. There are 2 fuses or 1 fuse and one relay in the fuse box under the hood i remove both of them and it still runs i have to disconnect the battery to get it to turn off. Is there anything i should try any ideas what it is doing?
Old May 18, 2005 | 08:34 PM
timzcat's Avatar
you should be pulling condensor fan relay if it's the front fan running.
Old May 18, 2005 | 08:36 PM
timzcat's Avatar
fuse 11 powers the condensor fan. In the relay box you want to look for the snowflake with a fan in it. Your pulling the wrong ones.
Old May 19, 2005 | 11:03 AM
so how do i fix it?
Jun 27, 2016 06:43 AM
HKSevolutionNYC
Feb 2, 2016 10:27 AM
seanb1979
Jul 2, 2015 02:10 PM
88888
Jun 13, 2013 08:40 PM
Bobster22388
Oct 26, 2009 10:35 AM
