Mbc Needed With Flash Control?
The nice thing about having an MBC or EBC with a flash is that if your flash is too rich you can simply increase the boost, and achieve more power with more air and a better AFR.
Without my MBC I would have been stuck with a power robbing 10.7:1 AFR.
I got an MBC and Al's Flash. It still tapers from 22psi to 20 psi.
I don't know if I got the V3 flash and if I didn't, I don't know why I didn't get it.
and Al's never answer one questions I've asked him on this board.
No one with the stock turbo can hold 22psi. It will always taper, some more than others, no matter what flash.
If Turbotrix or Works flashes were holding an extra 2psi to the top end and making more power I dont think Al would be in business...
Originally Posted by Rob W.
How do you swap in 15 minutes? Do you go in from the top or the bottom?
Just curious...
Just curious...
"The new "V3" flash that I developed mainatins amazingly steady boost..." -Al.
amazingly steady boost doesn't taper 3psi even with the hallman.
I think my hallman actually holded boost better before the flash. don't get me wrong, I like my flash so far, but this maybe a faulse advertising or bit exaggerated.
