Normal Oil Pressure Readings?
Old May 30, 2005 | 10:48 PM
KILTERMAN's Avatar
Question Normal Oil Pressure Readings?
My Defi Bf Runs At Idle At 1.25 Bar Or Whatever. Is This Normal For Everyone Else? Thanks
Old May 30, 2005 | 10:59 PM
scherejs's Avatar
that's like 18 psi, which i would think would be low. i thought it should be closer to 45.
Old May 30, 2005 | 11:02 PM
KILTERMAN's Avatar
DOES location of sensor matter?
EDIT here is where mine is located
Old May 30, 2005 | 11:21 PM
KILTERMAN's Avatar
Nvm.... Did a search every one has posted something to this nature after installing BF series gauges. especially using 5w-30 oil ( royal purple )
feel free to chime In but from the search I think I answered my own questions.
thanks
Old May 31, 2005 | 10:12 AM
kekek's Avatar
My car runs like this:
at start 6-7bar
as it warms up it drops, hot is about 1.25 to 1.5 bar at idle, this is NOT below Mitsu min spec
running hot is anywhere from 6 to 7 bar at higher rpm/loads
HTH
Old May 31, 2005 | 11:55 AM
Chris@nolimitmotors's Avatar
my car sits at 1.0 bar or even a little less at idle and thats with the defi bf amber
Old May 31, 2005 | 11:59 AM
instigator's Avatar
Mine is like 70PSI at idle at cold startup and if I drive it goes over 100psi. After the oil is 200 degrees, it is about 12-15 at idle and 55-60 at 75mph.
EyeDreamt
Jul 5, 2011 12:55 PM
evotris
Jun 1, 2010 03:54 PM
PorkRoll
19
Nov 12, 2007 10:50 AM
Mtcs
Future Lancer / Evo Models
13
Sep 7, 2004 02:08 PM
NRG
Aug 17, 2004 08:23 PM
