2nd gear grind?
Old Jun 2, 2005 | 05:58 PM
  #31
marksae's Avatar
Pennzoil Synchromesh is GL4, which meets our tranny requirement. Viscosity is around SAE80. FSM calls outs for 75W-90 or 75W-85. Jon@TRE says it's okay to use and doesn't cause any abnormal wear.
I went from using Redline MT90 to Pennzoil Synchromesh. The difference between the two is very noticeable. My shifts are a lot smoother and shifting notchiness has been reduced significantly. Redline shifts also require a lot less effort too.
The SS clutch line gives you a more direct clutch pedal feel. Less expansion in the clutch line translates to more clutch disengagement every time you step on the pedal.
The restrictor slows down how fast the clutch can engage and disengage. The purpose of this is to save the t-case from people doing redline clutch dumps. If you can control yourself from doing clutch drops, removing restrictor shouldn't cause any problems and should prolong your clutch life when you launch properly (i.e. slipping the clutch).
Old Jun 2, 2005 | 06:07 PM
  #32
EVIL_EVO_VIII's Avatar
Thanks for the info!
Old Jun 2, 2005 | 10:59 PM
  #33
EVORyan's Avatar
Likewise, thanks for the explanation Marksae
Old Jun 3, 2005 | 09:44 AM
  #34
BeavosEvo's Avatar
Originally Posted by EVORyan
This is very good info, can you tell me what the other benifits of swapping to a steel braided clutch line are, I am not familiar with this, but it seems be very popualar for the Evos. And could you also enlighten me on the clutch restrictor removal?
Having the stock rubber line allows the fluid to expand and stretch the line under pressure, steel does not. Most noticable when swapping the clutch line is the exact point of clutch engagement. Before it was somewhere in about a 1 inch arc when releasing the clutch, now it ALWAYS engages exactly at the same point (no guessing). As far as the restrictor removal, I believe there is a write up in the how-to section and on evomoto's web page (tech section). If you can't find anything let me know and I'll try to do a write up on it.
Old Jun 3, 2005 | 11:18 AM
  #35
EVORyan's Avatar
Awsome, thanks for the info, so it is basically the same idea as steel braided brake lines.
Old Jun 3, 2005 | 11:32 AM
  #36
BeavosEvo's Avatar
erh, kind of...Removing the restrictor cuts down on grinding/slipping and the steel braided line provides more accurate engagement. Just remember that removing the restrictor makes explaining any driveline problems to your dealer a bit tricky (I guess you could always put it back in if it came to that). The restrictor was put in by Mitsubishi to reduce tearing the T.C. and other parts to bits when launching at high rpms, unfortunately it also causes grinding and slipping and pretty much sucks azz for drag racing. So far I haven't had any problems with it removed and I haven't run into anyone else that has either.
Old Jun 4, 2005 | 07:06 AM
  #37
EVORyan's Avatar
I hate to get off topic here, (and if you think this is too off topic please PM me with an answer). Could you explain the transfer case issue to me, I am not familiar with it, I assume it is between the transmission and the axles, but 1)what is its basic function, 2)where exactly is it located, and 3)why can it be ripped apart at high RPM launches? Thanks for the info.
Old Jun 4, 2005 | 07:17 AM
  #38
evosilver's Avatar
2ed gringding
Originally Posted by EVIL_EVO_VIII
I keep gringding 2nd gear occasionally when shifting at high rpms toward or at redline. I think my clutch since it worn out, im assuming its not engaging properly. Im affraid that my 2nd gear syncros might be shot . I will be changing the tranny fluids this weekend, any suggestions would be great in which fluid to use to help. Thanks
changing the tranny fluids will make it smoother but it wont fix the prob i did it already and its bcoms smoother but it wont go away i had this prob on my 3ed and the only cause of ti is the hard and quick shifting if u can find an old used gearbox of an old evo then u will take there 2ed parts and palce them into urs thats what i did take care man
and about the oil i used 75w-90 its the best i think
aycynokia
May 10, 2011 05:33 AM
EVO8LTW
Feb 7, 2011 04:34 PM
ev0lution9
18
Jan 22, 2010 09:19 AM
Derekj03
24
Feb 26, 2005 12:40 PM
DsmAwdTurbo
Jan 20, 2005 12:37 PM
