anyone runnin denso 720's making 500whp???
Old Jun 3, 2005 | 12:22 PM
Chris@nolimitmotors's Avatar
I'm probably gonna run denso 720's with my gt35r setup but I keep seeing people running 880's with gt35r's. 720cc should be good up to 575 whp so if anyone is running around 500 whp let me know if your runnin 720's. Thanks
Old Jun 3, 2005 | 12:37 PM
nickracer9's Avatar
why not try some fic 750's for better spray pattern and extra hp! 720's should make 500whp, pump gas will be close.
Old Jun 3, 2005 | 01:37 PM
Widebandphillip's Avatar
720's will get run over by that 35r. There is a reason why people run 880ccs.
Old Jun 3, 2005 | 03:37 PM
AD_LIB's Avatar
buck up and get 1000cc densos....better safe than sorry right
Old Jun 3, 2005 | 05:00 PM
white05evoVIII's Avatar
these are what i am going to use. a friend of mine was using 880's on his evo with a gt35r, and he told me that at 22psi on pump gas (93) those injectors had a 93% duty cycle. so i would go with 1000's just to be on the safe side.
Old Jun 4, 2005 | 12:34 AM
T()()L's Avatar
Have an look here: http://www.rceng.com/technical.htm
Old Jun 4, 2005 | 02:34 AM
evo81's Avatar
500whp? i would think nothing less than 880's would work well on the car
Old Jun 4, 2005 | 06:19 AM
Ted B's Avatar
850cc/min is sufficient for 580-600hp.
Old Jun 5, 2005 | 03:03 PM
I guess greddy doesnt sell the 1000cc densos?
Old Jun 5, 2005 | 04:44 PM
Fas4dr's Avatar
With 780cc injectors, pump gas + alky injection, stock fuel rail/regulator, walbro 255hp my car put down 536 awhp on a mustang dyno. The injectors are only around 80% duty cycle.
Old Jun 5, 2005 | 06:20 PM
Smogrunner's Avatar
IE Evo makes 490whp/430ftlbs on 680's: Vishnu Stage 3 with a Garret 30R.
Old Jun 5, 2005 | 07:51 PM
VTECH8TR's Avatar
Damn, thats some power..
Old Jun 6, 2005 | 09:03 AM
ok so denso 720's should be fine then.
