question on Transfer Case
Old Jun 14, 2005 | 12:12 AM
Rcebowl's Avatar
i've heard a little bit about how they go out on Evo 8's
from what i can tell is that it's not as comon as the Clutch issue, but is still a common issue. So i had some questions
Why does it happen? just bad design?
When does it happen? is it just a problem when people lauch?
I've seen out people talk about new fluid helps the problem?
Sorry if this had been posted before, but it's something i did a little research in,
~ Vince
Old Jun 14, 2005 | 12:37 AM
evo81's Avatar
it's all about the way you drive
Old Jun 14, 2005 | 12:40 AM
1.8t's Avatar
Some say they are shimmed wrong from the factory, some say the transfer case is fine and that its the spider gears of the front diff that blow causingn transfer case failure and some say as long as you don't wheel hop on the launch she will last forever.
Old Jun 14, 2005 | 08:36 AM
EVIL_EVO_VIII's Avatar
Most of the tc problems have been due to wrong fluids put in which ****s up the ring and pinion which will cause a whine!! Spider gears inside the diff brake with 6k clutch drops or can break with wheel hop. Most of these break in 03-04's b/c of the open front diff and its garbage! The 05's have a helical lsd and should be stronger, dont know if anyone has blown one yet. I know Nolimit's 05 tc blew but dont know the reason. Get a spider gear upgrade from TRE I will be doing that soon or get the Quaiffe LSD!!
Old Jun 14, 2005 | 09:37 AM
MATT0404's Avatar
Wrong fluids and wrong launching techniques. Slip the clutch don't drop it.
Old Jun 14, 2005 | 10:47 AM
bolsen's Avatar
What he said.
Old Jun 14, 2005 | 10:59 AM
Tsurara's Avatar
Here is why you hear about TC problems:
Typical Dumb**** EvoM Member: Durrr, I am going to launch my car at 7,500RPM to impress the dumpy girl I am out on a date with!
Typical Dumb**** EvoM Member: Durrr, I will continue to do this at every stoplight to prove to everyone around what a fast car I drive.
Typical Dumb**** EvoM Member: Durr, my TC broke! **** Mitsubishi!#@
Old Jun 14, 2005 | 11:16 AM
Rcebowl's Avatar
lol word thanks
Old Jun 25, 2006 | 05:01 PM
MrMejia's Avatar
LMFAO!! +infinity to that one.
Old Jun 25, 2006 | 05:07 PM
smokedmustang's Avatar
Old Jun 27, 2006 | 12:48 PM
OZrallyracer's Avatar
Yes they do go out... I have an 05 and have the whining in my transfer case i think i'm gonna try to upgrade the spider gears soon.
Old Jun 27, 2006 | 01:22 PM
travman's Avatar
Derrrr.....I think yur right about that one?
Old Jun 28, 2006 | 12:35 AM
TurboTot's Avatar
the bolt to my transfer case had somehow came out to my transfer case,and drained it dry. i dont know how, it has to be the dealerships fault, but ofcourse they are not taking blame. ive been argueing with the service managers, and they are suppose to come to a decision soon on weather they are going to cover it or not. if not its going to cost me 4800 dollars. any ideas on what i could do? could it also have done any transmission problems to my car. they are saying it could have done that, but i dont know how.
Old Jun 28, 2006 | 01:25 AM
CammedEvo's Avatar
get a lawyer
fudlub
Lancer Troubleshooting
Jan 23, 2015 12:46 PM
ctfpevoVIII
29
Jun 5, 2013 07:34 AM
tehSteve
Nov 17, 2012 07:59 PM
DatRAzn
Jun 7, 2012 11:48 AM
jozilla69
Dec 17, 2004 10:40 AM
