New Bolt in turbo... FP White Rabbit.
Originally Posted by evo 8 ya
buschur has #s out on the 21g? where
-Paul
Originally Posted by mike 99gsx
Sweet threadjack
Originally Posted by PVD04
He hasn't dynoed it yet because he doesn't currently have a dyno. I believe he said it trapped 2mph faster at a lower boost setting than a stock turbo. It's in either his huge dyno thread or the 21G thread.
-Paul
-Paul
Originally Posted by davidbuschur
Deric
ps it seems your excitement towards this WR unit is as high as most of ours and something similar was your goal for the 21g...i'm glad to hear you support this turbo too.
Originally Posted by HiHeatEVO
I may have been premature in my statement, but from all the results and progress that you have posted, I have not been very impressed. Not that my opinion matters or if it is properly guided. I think that you can probably do better with it, and i think you're selling yourself short. I could be wrong, but that's my opinion. For those BR lovers that rush to defend him, i'm not saying i could do better, but i'm pretty sure he can do better. When you're as successful as he has been expectations go up. I just expect more i guess. I'd like to add that I am a fan of BR and I am happy to be in the same community as them. My comment was also misguided from my impatience/anxiety/excitement at the development of the 21g. I guess i'm just feeling a little let down.
Deric
Deric
A word of caution. I got a TME turbo back in November from a reputable source and while it works like a champ, it arrived at my house not ready to be installed.
You couldn't tell by looking at it, but long story short, make sure you check the wastegate actuator rod for the appropriate amount of pre-tension.
Remove the retaining clip, it's probably either a C clip or a pin. Make sure the distance between the eye of the rod and where it attaches is about 2mm or so, or just compare it to your stock setup.
Mine showed up with no pre-tension at all and that will yeild you sluggish boost that taps out at ~12psi. If you re-install the lower heat shield you're kinda screwed on getting back to that rod with the radiator in the car. In fact, if you do plan to re-install the lower heat shield you should notch it so that you can pull it out without removing the O2 sensor. A pair of tin snips should do the trick.
I figured I'd chime in as no one wants to spend time working on their car then have to diagnose what's wrong with the brand new part. Had I known this step I would have been a much happier person, as would my original radiator.....
Sam
Sam
Deric
Deric
Alright so I at least gotto see the WR, as he just had an exedy double quarter pounder installed. He has to break his clutch in so we did not go this time. I am sure he will have a right up on his car fo sho very soon. Did I mention that he is sportin 19 OZ Super's? The car looks tight.
Originally Posted by evoviiiyou
I am going for a ride in Fast Franks WR evo in about 30 min. Cannot wait to see her.
Originally Posted by dryad001
Damn. I'm out of popcorn.
The tension is building
hey evoviiiyou what kind tuning is done to the car?flash/standalone/piggyback?
like what they sell at the cinema's
