Flutter and Stall?
Old Jun 21, 2005 | 01:20 PM
Nvr2old32's Avatar
Flutter and Stall?
Need help!
I just had installed the following mods: (All Buschur)
Intake + Pipe
Downpipe
Highflow Cat
3'' I/C Pipe - Battery Kit
Flash
I already had a 3'' Catback & Greddy BOV installed (Recirculating). Now, when I step on the gas I hear a fluttering noise. Also, when I'm switching gears, my engine almost stalls. It did once today coming out of 2nd gear into neutral.
I think the issue is my blowoff valve which is either too hard or too soft. Which way should I adjust it to fix the stall issue and flutter?
Thanks.
Old Jun 21, 2005 | 01:24 PM
BRKENG's Avatar
I have a Bypass valve wich operates very much like a BoV.
I had to pit washers in the valve to increase teh tension on the spring. Try increasing teh spring compression in the BoV.
Tim
Old Jun 21, 2005 | 03:10 PM
GTVEVO's Avatar
Originally Posted by Nvr2old32
Need help!
Intake + Pipe
Downpipe
Highflow Cat
Flash
Thanks.
Most likley it is too stiff. Just keep trying softer settings and test in 5th gear a low rpms on and off boost till the flutter goes away.
Old Jun 21, 2005 | 05:06 PM
evotuner's Avatar
Yes, it sounds like an issue with the BOV spring.
Old Jul 29, 2005 | 07:19 PM
Genesis8's Avatar
Mine is fluttering too...but I have a JDM MR Diverter. I got it after Ive installed my TurboXs FMIC and XS Engineering piping. Any suggestion guys......
Old Jul 29, 2005 | 07:32 PM
GOKOU's Avatar
Did you perform the spring mod? If not you need to do it.
http://www.evomoto.com/tech_info.php?tPath=1&tech_id=7
Old Jul 29, 2005 | 07:35 PM
Genesis8's Avatar
Spring Mod????
Old Jul 29, 2005 | 07:36 PM
GOKOU's Avatar
Originally Posted by Genesis8
Spring Mod????
This is only if you have the greddy type S. IF you have the jdm bov there's not much you can do since the spring tension is not adjustable.
Old Jul 29, 2005 | 07:39 PM
Genesis8's Avatar
But I have a JDM MR DIVERTER......Is that possible..
Old Jul 29, 2005 | 07:40 PM
Genesis8's Avatar
Any other suggestions????
Old Jul 29, 2005 | 07:42 PM
nhsean69's Avatar
To answer the first guys question....I had the same issues with the Type-s, Follow the steps for the single spring mod and everything will be fine.
Old Jul 30, 2005 | 05:58 AM
PoorBoys's Avatar
Sounds like compressor surge to me. From what I hear a blowthrough MAF should help.
https://www.evolutionm.net/forums/sh...d.php?t=145873
Old Jul 30, 2005 | 07:38 AM
Void's Avatar
i have relatively same mods with the greddy type-s and had the same stalling issue. so i bought a forge bov and it fixed it!
Old Jul 30, 2005 | 08:54 AM
nhsean69's Avatar
The problem is with the BOV, notice how a new BOV or the Single Spring mod fixes the issue, puilling out a sping seems a lot more econimical then spending the cash on another BOV. Seems like pulling out 8 screws is alot easier ........ but hey its your money.
J Yim
Jan 25, 2016 01:00 PM
TrackDays
26
Mar 14, 2011 07:32 PM
evo unknown
Oct 19, 2009 08:29 AM
joon82
12
Jul 8, 2007 05:52 AM
broddey
22
Feb 2, 2006 07:32 AM
