DIY Pressure tester (pic) and leaks found so far
Old Aug 28, 2005 | 02:38 AM
  #61
David Buschur's Avatar
Not sure how old some of the lower i/c pipes are that are being talked about but I agree none the less, they are a pain to install.
For the last 6 months or so we have been including instructions with the Deluxe FMIC kit to help guys get that pipe on the right way.
First let me make sure to say, each one of those lower pipes are machined perfectly flat before we ship them. IF anyone's is "warped" it is from putting it on improperly as they are flat when they leave.
Pull the starter off AND take the wastegate actuator off the car. Then put the pipe on, makes it much easier AND insures the pipe is bolted on flat to the turbo. Then you can put the other parts back on.
I have no excuse for the pin hole found in the pipe. Probably happended at the end of the weld when you pull the tungsten away. I apologize, would have gladly paid shipping and re-welded it for you. Also glad to hear that although there was a pin hole it didn't effect the boost level.
I had two cars on the dyno this week that wouldn't hold boost. Did a quick boost leak check and both had fairly severe leaks. One was at the lower i/c pipe coupling, clamp was crooked and the other was at the lower bolt hole on where the TB bolts to a sheetmetal intake manifold.
David Buschur
www.buschurracing.com
Old Aug 28, 2005 | 04:41 AM
  #62
EVO8LTW's Avatar
David, I've seen you post this suggestion before and I can't say that I understand it. If you drop the wastegate actuator and then put the lower IC pipe on, then the actuator isn't going to fit back on flush since it will be against the lower IC pipe. Are you perhaps leaving out the step of shimming the actuator so that everything can be bolted down securely? My fix for this was to put a dent in the lower IC pipe for clearance with the actuator.
Old Aug 29, 2005 | 06:48 AM
  #63
The main thing is making sure that the lower pipe fits flat and tight to the turbo. IF the actuator then hits the pipe when you re-install it you can either put a washer behind the actuator or simply use a screwdriver to pry gently on the actuator bracket to bend it slightly to the side.
The lower i/c pipes have been changed over the last 3-4 months to allow more clearance there, so newer ones shouldn't be much of or any issue.
David Buschur
Old Sep 7, 2005 | 05:07 PM
  #64
Evoisdream's Avatar
ok so i officially think i have a bad leak my boost isnt getting full spool till like 4500 thats with the stock turbo hahahah but whats weird is it holds 21psi fine?.... so with the tester should i cap off the top of the IC pipe at the throttle body or should i just set the motor to tdc ? thanks
Old Sep 8, 2005 | 12:30 AM
  #65
Evoisdream's Avatar
so im gonna do this today ne help with the TDC or capping it off would b great or ne ideas where i should look i think its a leak? i mean it was holding boost fine once it got thier just Took forever!!!!!!!!!!
Old Sep 8, 2005 | 08:28 AM
  #66
arpad's Avatar
i do both... first i cap it at the throttle body and test the IC pipes alone for leaks, then i attach it at the throttle body, set it to tdc and test for vacuum hoses that may have blown off. makes it much easier to isolate a possible problem...
Old Sep 8, 2005 | 10:31 AM
  #67
revolagoy's Avatar
Well, I finally got around to doing this. Had some weird results. I hooked up my pressure tester at the turbo and plugged the line going to the BCS(the one closer to the front of the car coming from the turbo) and the crank case ventilation hose that goes into the intake track. Next I hooked up my cigarette lighter compressor(means the ignition was on). I pumped up the pressure till my boost gauge hit 15 psi. It would go no higher. So, I try again and this time only 10psi. I try a third time and the oil dipstick shoots out of the engine bay! I thinking WTF caused that. So, I open the oil cap and all this pressurized air comes out. I try one more time and back to 15psi and no higher. I didn't hear any leaks anywhere. I also crawed under the car with the undertray removed and still no sound of any leaks.
I put everything back together and when I started the car I got two SES P0107(MAP/BARO Circuit Low Input) and P0113 (IAT Sensor 1 Circuit High Input). I reset the ECU and the car drives fine.
Any ideas what happend?????
Old Sep 8, 2005 | 11:00 AM
  #68
Evoisdream's Avatar
hrmmm did u set the motor to Tdc?
Old Sep 8, 2005 | 11:43 AM
  #69
revolagoy's Avatar
No. Is that necessary to do the test? I have read on other threads that it doesn't matter if the engine is at TDC.
Old Sep 8, 2005 | 05:34 PM
  #70
Evoisdream's Avatar
ok guys just got done doing this huge hole in the IC pipe coupler hahahaha i took some pics if anyone needs one
Old Sep 9, 2005 | 12:44 PM
  #71
revolagoy's Avatar
Bump. Any Ideas?
Old Sep 9, 2005 | 02:16 PM
  #72
Huge hole in an i/c coupling, that sucks. Engine mounts are the cure. They should be SOON!
David Buschur
Old Sep 9, 2005 | 02:20 PM
  #73
Evoisdream's Avatar
it was ur IC coupler lol it was my bad i had it put on weird from when i finished up my clutch and rushed it cant blame anyone but myself not a big deal local guys sell all new ones so i just got a new one
Old Sep 9, 2005 | 02:22 PM
  #74
It doesn't surprise me, the problem is the engine moving so much though. It rips couplings.
David Buschur
Old Sep 9, 2005 | 02:36 PM
  #75
Evoisdream's Avatar
werd makes sense
