ACT after break in question
Old Jul 16, 2005 | 09:23 AM
threepointsix's Avatar
Originally Posted by marksae
Clutch pedal adjustment info:
http://www.evomoto.com/tech_info.php?tech_id=28
Braided Clutch Line Install / Restrictor Removal:
http://www.evomoto.com/tech_info.php...=3_4&tech_id=4
Thank you.
Old Jul 16, 2005 | 09:50 AM
mhgsx's Avatar
Originally Posted by GOKOU
Thanks for the information. I bought the ACT clutch and had a friend of a friend install it so not sure if release bearing was install properly. I would hope it did. Re-used the stock flywheel but resurfaced it.
Just problems quick shifting at high rpm. Under normal driving it goes fine.
Did you also change your trans fluid at the same time? Redline MT-90? I had the same problem when I changed to Redline fluid w/ the stock clutch. It wouldn't shift at WOT @ high RPMS. Immediately changed it to a 1/3 Redline, 2/3 Synchromesh and it works fine.
Old Jul 16, 2005 | 10:52 AM
GOKOU's Avatar
Yes and I just change it out again last weekend. I use pennzoil SM.
Old Aug 9, 2005 | 11:19 PM
XxBLACKMAMBAxX's Avatar
I had the same problem with the RRE clutch. I tried switching from Redline to SM oil, no dice, same thing. Your engaugment is too low, you have to adjust the pedal higher (screw turned out of the pedal, which would be clockwise looking at it facing the firewall). I did this a few times and it didnt help, then I finnally just adjusted the **** out of it till there was half an inch of freeplay only, the clutch engauged high and was uncomfortable but I was able to shift at 7500 no problem. I have heard the ACT shouldnt be that extreme cause the RRE disc is a lot heavier, but I still say try adjusting it all the way up and go from there, if it fixes it, slowly adjust it back down till you cant shift it anymore, then back it up half a turn, you should be done. Its a lot of tedious trial and error, but once you fix it you will be alot happier. Good luck
Old Aug 10, 2005 | 05:45 AM
nnorris7413's Avatar
I was just about to make a thread asking the exact same question. Looks like I dont need to any more.
AJ18
19
Apr 21, 2017 08:15 AM
Evo10HKS
Aug 10, 2016 06:14 AM
sliknik874
Jun 21, 2011 09:10 PM
theLAM
19
Mar 21, 2010 03:52 PM
Evo9Kid
May 14, 2006 08:59 AM
