White Rabbit Discussion - MERGED
Old Jul 18, 2005 | 11:31 PM
KILTERMAN's Avatar
Damn, Look at 2600 - 5200 . thats quite an improvement
Old Jul 18, 2005 | 11:34 PM
evo_dadi's Avatar
mods consists of:tbe/264cams/mbc/s-afc/walbro pump/660cc injectors.ill probly get more with some more tuning and with better temp for the day.but tuning on a hot day is kinda good also since you know with harsh conditions youre still making some power
Old Jul 18, 2005 | 11:40 PM
whiteevo311's Avatar
did you dyno before and after the cams. im thinking of going with the 264s. How much power did you make with the cams? thanks
Old Jul 18, 2005 | 11:43 PM
PHILLY EVO's Avatar
Who made the white rabbit
evo_dadi's Avatar
the base has everything that i listed on it before the white rabbit.the only difference was i had the fp hotside and the helix o2 housing before but not anymore.
TomeiEvo's Avatar
YOu can't feel 6 WHP but you will surely feel the additional 16 ft/ib of torque there!! I have the same mods as you but with HKS 272's, am eager to see what mine does regardless of what everybody says in the other thread...
Old Jul 18, 2005 | 11:48 PM
evo_dadi's Avatar
enjoy it definitely man
Old Jul 19, 2005 | 12:04 AM
machron1's Avatar
I'm assuming that people will start seeing bigger gains when they actually tune to the new turbo's capabilities. It's obvious it spools as fast as stock and has gains over just about the whole useable power band, but what isn't obvious is that the air is probably a lot cooler and the turbo probably is capable of pushing out more cool air at higher RPM's as well. With cooler air you can lean out the mix a bit, and keep the timing advanced more. With more flow obviously you can keep the boost from tapering up top as well, and you won't be maxing out the turbo & just blowing hot air up in the higher rpms as well. If people are expecting huge gains without tuning to the new turbo it just won't happen, but it's great to see even without tuning it is making a little more power.
Old Jul 19, 2005 | 12:19 AM
CRVdrftR05's Avatar
Uh....why were they closed in teh first place? Is the WR illegal or something?
Old Jul 19, 2005 | 12:27 AM
machron1's Avatar
Dunno why, but the WR has generated so much hype (good & bad) that the threads got very heated. Maybe this thread will be better. I don't see what's so hard about letting people post dyno sheets and personal experiences without *****ing about every little detail and discounting everything. Time and lots of data points will show how this turbo is overall. I think it would be great for a person like me who enjoys quick spooling and low RPM torque for track days and doesn't really need HUGE horsepower. If we just simmer down and let the information flow we will find out for sure...
Old Jul 19, 2005 | 12:31 AM
machron1's Avatar
Wow, so since the hot and cold side housings are roughly the same size as what you had before, all that low end grunt can be attributed to the new turbine/compressor wheel designs and lighter materials with no extra tuning at all? Pretty good, especially for a non-ball bearing turbo.
How does the transient boost response feel now? Quicker spool between shifts?
Old Jul 19, 2005 | 01:52 AM
RaceBiscuit's Avatar
wow, seems like the White Rabbit hype just got started and now it's being "shut down?" doh!!!!!
Old Jul 19, 2005 | 04:35 AM
gsujeff55's Avatar
But, did doug test the car on race fuel at 27psi? Not bashing him, just can't remember if he did pump gas or race.
Old Jul 19, 2005 | 04:51 AM
Az3ar's Avatar
Nice write up. I just dont understand how it will make power as Al, TT and Vishnu could not extract much power from it. The three of them were very close to each other results. Its a bit hard to buy this turbo and take it to Tim thinking that he is the only tuner to do things right!!!!
after all, we still need some dyno numbers from 3rd party tuner with a flash.
Old Jul 19, 2005 | 05:10 AM
Speedlimit's Avatar
Admin Emeritus
Originally Posted by joeycoates
I cannot believe that all of the WR threads have been shut down and that ForcedPerf's responce was erased. I do not cause much trouble here, but that is rediculous. So are the words "white rabbit" never to be spoken of here again? Sounds like "Voldemort" from Harry Potter or something, maybe if we just ignore it and peoples opinions then they will go away......
Did SpeedLimit have anything to do with this?
Hi,
Your comments reflect exactly why both threads were closed. Specifically, taking little information and building a mountain of BS. Both threads had become useless because of all the fighting. Your assertion that FP's White Rabbit is banned from discussion here is stupid. Finally, Force'd Perf's comments were not removed:
https://www.evolutionm.net/forums/sh...&postcount=171
Speedlimit.....
PS I close those messes.
