20G turbo upgrade from Buschur Racing.
Old Aug 29, 2005 | 08:50 PM
  #301
machron1's Avatar
fine I give up...this aside has run its course and I don't want to mess up this thread...I guess the general consensus is without a BOV the air just slips around the compressor wheel without slowing it down or stopping it, and the bucking...well since it couldn't possibly be because the turbine wheel has stalled from the backpressure on the compressor, if and when it ever happens to me again I guess I'll really check for a banana in my tailpipe.
Old Aug 29, 2005 | 08:55 PM
  #302
wannaevo's Avatar
Hey David how does this turbo compare to the 05 EVO turbo>? What are the gain on this turbo over the 05evo turbo. Can't wait to see some results soon.
Thanks Or if anyone else can answer this that would be good also.
Chris
Old Aug 30, 2005 | 05:20 AM
  #303
David Buschur's Avatar
Creamo3, we shipped some turbos, not sure if yours was one of them. If you ordered the turbo with a turbine housing it should be adjusted. Very simple to check before you install it though and I would suggest doing that.
machron1, what you are saying is partially correct. Compressor surge doesn't only happen with the throttle plate is closed or only partially open. Many turbo will surge even under WOT conditions.
David Buschur
www.buschurracing.com
Old Aug 30, 2005 | 05:21 AM
  #304
The '05 EVO turbo is what I upgraded on my car to the 20G.
David Buschur
Old Aug 30, 2005 | 06:06 AM
  #305
deadbeatrec's Avatar
i am still awaiting some results.
Old Aug 30, 2005 | 11:54 AM
  #306
There are units out there, guys just have to get them on the cars now. My car put down results, I am assuming you need more.
David Buschur
Old Aug 30, 2005 | 12:12 PM
  #307
well its either a upgraded 16g or a bigger turbo kit for me. i want some serious pull from something big without haveing to spend more then 3g u know.
Old Aug 30, 2005 | 11:08 PM
  #308
memo3's Avatar
This would be little late to the topic but I was actually in Dave's car before the shootout. The white one of course with 20G and there was 3 people in the car including me (I weigh about 250lbs) so do the math. I have a Stage4 car that I drive daily. All I can say is, this 20g is a very big difference when you compare it to stock turbo/stage4. It has a lot more top end and kicks in just like stock.
That day, the boost around 25psi was holding very steady and it spooled very identical to stock, you can't tell if it is stock or not until the boost hits and pulls like a plane, that's where you say woow..
Old Aug 31, 2005 | 09:04 AM
  #309
Supernaut's Avatar
Sounds promising, I have always run Buschur Parts on my DSM and now my Evo. His Customer service alone is worth it
Old Sep 6, 2005 | 09:19 AM
  #310
Iceman2011's Avatar
anybody got their 20G yet and have it dynoed
Old Sep 15, 2005 | 12:49 PM
  #311
WannaRace's Avatar
I see it up on their website now, anyone have any results they'd like to share yet?
Old Sep 15, 2005 | 12:54 PM
  #312
MalibuJack's Avatar
Nothing yet here.. My car was rear-ended and is in the shop getting repaired.. I'm also waiting for some parts to come back from being ceramic coated..
Old Sep 15, 2005 | 12:57 PM
  #313
WannaRace's Avatar
Sorry to hear that, it is your results that I am most anxious about
Old Oct 8, 2005 | 10:17 AM
  #314
MalibuJack's Avatar
Here's a quick update and preview, my car just came back from the bodyshop, they damaged the electronic box for my blowthrough MAF, so I am waiting to replace some electronics, but I picked up the thermal coated header and O2 housing yesterday and assembled everything with brand new hardware.
What you see in this picture..
JIC Header
TME Based 20G turbo with 10.5 housing
DNP O2 housing
EGT Sensor
Forge adjustable wastegate actuator
The header and O2 housing is Thermal Coated by Rainbow Powder Coat here on Long Island, NY.. Their pricing blew away the competition and of course it didn't cost anything for shipping.
I also used all brand new OEM hardware to put everything together, I didn't want to be caught salvaging or swapping rusty parts. When I do finally install everything the hardware will get professional copper anti-seize on it so I can get this stuff apart in the future for the turbo comparo I'm planning after I move into my new house and shop.
Old Oct 8, 2005 | 11:01 AM
  #315
EvoTio's Avatar
Wow, that looks great! Where can I purchase that copper anti-seize that you will be using?
