20G turbo upgrade from Buschur Racing.
Originally Posted by davidbuschur
use2vtec,
The specs have been posted a lot, probably in this thread. It's been awhile so here it is again:
Buschur Racing Stage 4 kit. (parts below are optional in the stages)
*Race FMIC
*880 cc injectors
*280 camshafts
AEM EMS
BR Stage 3 head
BR Stage 3 shortblock
Exedy HD twin disc
BR20G-EVO9
David Buschur
www.buschurracing.com
*Race FMIC
*880 cc injectors
*280 camshafts
AEM EMS
BR Stage 3 head
Exedy HD twin disc
BR20G-EVO9
David Buschur
Dave,
My order is in
for the BR20G-EVO9. Now the hard part is waiting for it
Originally Posted by dr_speed
Just to get an idea on the surge of the normal Evo8-20g. Compared to a stock 03 turbo, is it more? less? My stock 03 can surge pretty bad.
Actually I think I probably have the worste surge of anyone on my personal car. We have shipped quite a few of these 20g-8's and the complaints haven't been bad. My car is very built which I am sure helps with spooling the turbo. I also run the heaviest spring I can get in my BOV. I don't think most guys BOV's are nearly as tight as mine and this adds to the surge.
To answer you directly, the 20G-8 (8 is for EVO8 turbo, 20G-9 designates EVO9 turbo) surges quite a bit more than the stock turbo.
David Buschur
David Buschur
Originally Posted by Ultimate CC
Well as of right now I haven't seen any of these 20gs or white rabbits doing that much better at the track than stock turbos have. This new hybrid seems promising.
WHich track are you talking about. Not a straight line, hopefully...
David Buschur
David Buschur
Just food for thought
Hey Dave,
Are you still going to sell the old style 20gEvo8 TME ? Or are you going to take it off the shelf when you fix the surging problems.
If so, can you give us an estimate to how much more it would be for the upgraded 20gEvo8 TME.
Thanks man !
Thanks man !
Originally Posted by kmcconn9
/\ +1. By that time there will be "several" other BR20g-9's out there with results...so a little time wont hurt anything..
meanwhile I have these mods going into my car in December 05:
HKS 280's---> on hand
Camgears---> on hand
ARP headstuds---> on hand
Walboro 255 FP---> on hand
AEM EMS with MAF delete---> on order
SMC V2 Meth kit---> on order
and some custom wideband tuning
hopefully by the time I'm done I can do the turbo once all the results are out.
Originally Posted by DynoFlash
Actually David - I had an interesting experince yesterday in Seattle tuning a W/R equiped evo with upgraded wastegate actuator which surged the same as in your white car
Almost looks like my sheet Dave
, can't wait to upgrade come spring time.stock turbo graph
Answers to questions:
The 20G-8 (EVO8 20g) will still be sold. It works too good and costs a lot less for a guy that already has an EVO8 turbo to not sell it. Yes, it surges, but I had it on my car and loved it. If you already own an EVO8 turbo and want to upgrade it, it is $800 for the upgrade, using your existing tubine housing and such. $300 for a 10.5 new hotside.
The 20G-9 (EVO9 20g) is also $800 for the upgrade if you happen to be lucky enough to already have an EVO9 turbo.
I am running our ported and coated exhaust manifold, 10.5 turbine housing and 02 housing.
Pete,
I should have used your car as an example in all this. I forgot how much power your car made. Your car is very close to mine in the build-up except it uses a stock turbo and alky. This is an excellent indicator on how fast the turbo actually spools. If you notice on your dyno sheet you hit max torque at 4250, same RPM the 20g-9 on my car does but the 20G (and other parts I have you don't) make an additional 34 ft lbs. Same with the HP, comparing spool up the 20g-9 actually peaks 250 rpm sooner. More interesting than that though is how broad the HP curve is on the 20g-9. Your stock turbo doesn't hit 300 whp until 5200 rpm and then stays there until 7,000 rpm, nice. Look at the 20G graph though, it hits 300 whp at about 4500 rpm. Very interesting comparing these two.
I was trying to think of a good Stage 4 example when I was coming up with a comparison chart. I should have used yours.
Thanks for the questions guys,
David Buschur
Pete,
David Buschur
