20G turbo upgrade from Buschur Racing.
Old Nov 13, 2005 | 07:10 PM
  #421
jbfoco's Avatar
Let us know when you are going to have them in stock so i can place an order
Deposits???
Old Nov 13, 2005 | 07:15 PM
  #422
inariv5573's Avatar
Originally Posted by SEEYA
read closer, that is for the entire turbo INCLUDING installation kit...
Oh thanks for verifying that. Since you put it that way, that is an AWESOME deal! So if I supply a core it would be cheaper. Just wondering if it would be cheaper to buy a used Evo 9 turbo from someone and send it in for a core. Or just buy the whole thing from Buschur w/o a core. Since I will be paying for a another turbo either way. (I have an '03)
Old Nov 13, 2005 | 07:20 PM
  #423
inariv5573's Avatar
Originally Posted by anjapower
I'd like to know how much of an improvement this is over a stock IX turbo, and the VIII based 20g.
Please give Dave a chance to do his research. These 9's just came out for Pete's sake. Dave had just gotten hold of one. I am pretty sure it will make more power than an Evo 9 stock 16G, obviously. And it will most likely make more than the Evo 8 20G. Stock Evo 9 makes more than 8. You need to use common sense. Not to mention the larger compressor housing should solve the surging issue.
Old Nov 13, 2005 | 07:31 PM
  #424
anjapower's Avatar
Of course...but I'd still like to know rough estimates of how much whp each stage gives.
Old Nov 13, 2005 | 07:33 PM
  #425
inariv5573's Avatar
I definitely want to know as well. I may invest in this kit. Just give him time. He always comes through.
Old Nov 13, 2005 | 10:07 PM
  #426
rACerS's Avatar
What kind of gains in mph do you think you would gain at the track over an 05 evo turbo (at the same boost).
thanks
Old Nov 14, 2005 | 07:14 AM
  #427
David Buschur's Avatar
Some of the questions that have been asked I can't answer until later in the day, I have to find out.
zstryder,
The lower i/c pipe for the EVO9 is going to be different than the EVO8's. I have already started working on this and have the initial pipe done. I have to do some test fitting on some other cars.
EVO8LTW,
I'll get back to you on the TME internals, I don't remember.
Kmcomm9,
The $1580 is for the turbo and installation kit. The actuators right now are $175, making the total $1755. I think I can get the price down a little, I am going to check later today.
Carliebrown,
Race gas this turbo will make atleast 375 on our dyno, with a good driver this enough for 10's.
jbfoco,
The turbos are going to get ordered today. Not sure how long it will be. I'd suggest calling and placing your order ASAP. We won't charge your card until it comes in and we will fill the orders as they were recieved when they do come in.
David Buschur
www.buschurracing.com
Old Nov 14, 2005 | 08:32 AM
  #428
MalibuJack's Avatar
Out of curiosity, might be able to retrofit the compressor cover to an earlier turbo if you get the mitsubishi rebuild kit for the Evo9 turbo, The diffuser backplate, snapring, and compressor wheel (and bearings) may be the only real differences.. The kit should only be a few hundred dollars.. could make sourcing cores alot cheaper.
if someone has the part numbers for the Evo9 compressor cover and turbo rebuild kit I can order the parts and compare them for you
Old Nov 14, 2005 | 08:48 AM
  #429
Mike@Forge's Avatar
Does anyone have the part number for the OEM Evo 9 wastegate actuator? David?
We need to order one (or be supplied with someone's) to prototype our own version!
Old Nov 14, 2005 | 11:57 AM
  #430
malibu,
It isn't possible. The back plate is part of the cartridge, we already tried to do this.
Mike, give us a call and I will give you the part number.
David Buschur
Old Nov 14, 2005 | 12:07 PM
  #431
justchil's Avatar
I'm glad I waited I'll have to get mine with the IX housing!
Old Nov 14, 2005 | 02:10 PM
  #432
MalibuJack's Avatar
Originally Posted by davidbuschur
malibu,
David Buschur
Ahh damn, I thought I was onto something..
Old Nov 14, 2005 | 05:34 PM
  #433
TEH FASTR EVO's Avatar
I really wana see how this thing can make more power then a 3071 for 99% of the Graph, if this is true they may be on to something. Ima liking the torque.
Old Nov 14, 2005 | 06:46 PM
  #434
Ev0ikon's Avatar
This looks to ogood to be true. It totally kills the 3071 where it counts. From graph, my feeling of the 03stock turbo in the back like a hammer will then feel like a wrecking ball!
Let me know when I can place the order
Old Nov 14, 2005 | 06:57 PM
  #435
MR's Avatar
MR
Hi David,
U have a PM...
Thanks...
malibu,
David Buschur
