20G turbo upgrade from Buschur Racing.
Old Jan 7, 2006 | 12:39 PM
  #676
ct9a gsr's Avatar
Originally Posted by Smogrunner
To give perspective, A stock '03 evo makes about 230whp on a dynojet 424x
230 + 140= 370whp
Dave,
That is what many many of us make all over the country. And tons of us go out and run 113 to 115 mph at the track with those kind of numbers. Now, with your top notch drivers and bit of extra weight removal, there is no way you should do better than 117mph.
Your numbers simply don't add up.
Just for reference, my Evo's rated at 389whp (19whp more than your 370whp #) and I run 118mph w/ absolutely no weight reduction + spare + tools in the trunk.
Old Jan 7, 2006 | 12:44 PM
  #677
Smogrunner's Avatar
Exactly what kind of dyno? If that was on a Dynojet on SAE correction, those numbers perfectly back up the point I am trying to make.
Old Jan 7, 2006 | 01:42 PM
  #678
LIFER's Avatar
I have a hard time with the math on this achievement.
Stock on your dyno = 213
Stock MPH in 1/4 = about 104
328 whp = 115 whp over stock
Your MPH = 124
So, you are honestly claiming that you gained 20mph in the quarter with just 115 more horsepower.
even when adding 22% to compare to a dynojet you make 140whp over stock.
To give perspective, A stock '03 evo using STD correction, makes about 230whp on a dynojet 424x
230 + 140= 370whp
Dave,
Finally, I know that you (and others) are going to feel the need to personally insult me. But please, please, answer my question when you are finished.
I will give you some very simple facts, so that I make this black and white for you.
On David's dyno I put down 275whp wich is only about 70whp more than stock 03 evo's put down on his dyno, and I ran 11.8@116
70whp = 12-13mph gain over stock
David put down 340whp the same dyno @ ran a 124 trap.. Thats 135whp more than the 03's put down stock on "HIS" dyno.
135whp=20-21mph gain over stock
How does that not make since?? You can say his dyno may read low. But you cant say 124mph traps are not possible with 340whp on his dyno.
Old Jan 7, 2006 | 01:52 PM
  #679
Smogrunner's Avatar
For starters, where are you getting the 340whp figure from? I directly quoted David Buschur who states that he did 124mph on 328whp.
Lets just get on the same page.
Old Jan 7, 2006 | 01:55 PM
  #680
LIFER's Avatar
For starters, where are you getting the 340whp figure from? I directly quoted who states that he did 124mph on 328whp.
O so the extra 16whp I typed by mistake, means it never could happen?
Its still 120whp more than a stock 03 puts down on his dyno..
and I traped 14mph faster than a stock 03 with only 70whp more
whats the point of having a "truth squad" when they can't see the truth when it's in there face
Old Jan 7, 2006 | 01:59 PM
  #681
DragNRacing's Avatar
+1
Old Jan 7, 2006 | 02:09 PM
  #682
Smogrunner's Avatar
Ok,
Using David Buschurs own calculations of 22% variation between his dyno and the all wheel drive dynojet of Tym Switzer's:
275whp + 22% = 335.5whp.
OK, I think I might be on to something here. If you are doing 11.8 at 116 on 335whp the track you race at is not accurate -OR- you have removed around 400 to 500lbs from your car.
I can post up hordes of guys with average evos making 330 to 340 whp on dynojets who go out to the track and NEVER get passed 112mph.
Old Jan 7, 2006 | 02:15 PM
  #683
mhgsx's Avatar
Ok,
Your math is wrong. It should be 275/0.78 = 352.6 hp.
  #684
LIFER's Avatar
Ok,
A normal mustang dyno reads 22% less than a dynojet... David's is more like 30% on avg.
Old Jan 7, 2006 | 02:20 PM
  #685
mhgsx's Avatar
Also. do we know for a fact that a +10 HP gain on a Dynojet is equal to a +10 HP gain on DB's dyno? It would seem to me that each HP should be correspondingly adjusted, and that it doesn't follow a 1:1 ratio after baseline.
Old Jan 7, 2006 | 02:27 PM
  #686
Smogrunner's Avatar
I'm sorry, your math is wrong, as is your formula above.
Old Jan 7, 2006 | 02:31 PM
  #687
LIFER's Avatar
What is it with you and alway's questioning everything that David say's.. You seem kinda bias for a title like "truth squad"
Old Jan 7, 2006 | 02:37 PM
  #688
Boosted AWD's Avatar
Evo IX 20G may just be the ticket, what injectors are needed and will a FMIC upgrade be needed?
Old Jan 7, 2006 | 02:48 PM
  #689
Smogrunner's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=175482
Please read for yourself. David B himself rated his dyno to read 22% lower than Tym's dynojet. Furthermore, DB called it the "End All Comparison," implying that the results were definitive. You, on the other hand, are truly pulling this 30% number from thin air.
Old Jan 7, 2006 | 02:52 PM
  #690
EVO8LTW's Avatar
Your MPH = 124
I think that the answer lies in the shape of the power curve and the weight reduction mods. The BR RS makes huge midrange compared to other Evos making similar peak numbers, and we've all seen enough dyno queen big turbo cars at the track to know that there's more to 1/4 performance than peak numbers.
