ACT clutch with flywheel?
Old Jan 9, 2006 | 03:28 PM
  #76
nigletsyz's Avatar
Originally Posted by ACTman
BTW, the clutch bolts should be tightened to around 25 ftlbs. Actually we recommend 30 for racing (if you are using brand new 10.9 grade bolts).
Are you talking about the small pressure plate bolts? I think there are six. If so, be careful torquing these down.... they are cheap zinc bolts and will snap if you tighten them too much. Spec is 23 ft/lbs. I snapped one during an install and couldn't believe it... I though I was barely tightening it. Hopefully, your local Mitsu dealer will have these in stock (unlikely) if you ruin one. Also, i wouldn't recommend using locktight on your flywheel bolts. I torqued a flywheel down to 105 ft/lbs once and had the hardest time getting the flywheel off when it came time to replace the clutch again. I used a 250ft/lb impact gun and it didn't touch it. Eventually I got all of them except one off with a huge breaker bar. One was rounded and had to be dremeled off. Closest flywheel bolts were 200 miles away. Not fun. So moral is... read your torque specs on these pertinent bolts. Don't use locktight, you'll probably regret it.
Old Jan 9, 2006 | 04:19 PM
  #77
ACTman's Avatar
Originally Posted by nigletsyz
Are you talking about the small pressure plate bolts? I think there are six. If so, be careful torquing these down.... they are cheap zinc bolts and will snap if you tighten them too much. Spec is 23 ft/lbs. I snapped one during an install and couldn't believe it... I though I was barely tightening it. Hopefully, your local Mitsu dealer will have these in stock (unlikely) if you ruin one...
Yes the 8mm bolts and yes they are easy to twist off. When I said 30 ftlbs, I stated with brand new grade 10.9 bolts. The 10.9 bolts twist off at about 36+ ftlbs. I wasn't sure what grade the stock bolts are.
Old Jan 9, 2006 | 11:48 PM
  #78
Mayhew333's Avatar
Great info guys.
Listen to ACTman.
drink a bunch of them and rip that sucker back out.
It sucks but it'll save you a lot of money and anquish.
SsZERO
36
Sep 24, 2010 07:10 AM
Mr. Evo IX
12
Jun 26, 2008 09:21 PM
GIXXER05
Jan 24, 2008 07:31 AM
EVIL_EVO_VIII
Mar 23, 2005 08:42 AM
93civEJ1
24
Mar 10, 2005 12:17 PM
