P0234 - how does the ecu sense the car is overboosting??
Old Aug 7, 2005 | 03:28 AM
SlowCar's Avatar
How does the ecu sense the car is overboosting?
Old Aug 7, 2005 | 03:50 AM
awdjunkies's Avatar
A/F ? .........
Boost levels are recorded onto the ecu from the factory.
Anyone else?
Or am i totally wrong on this
Old Aug 7, 2005 | 04:21 AM
bertune's Avatar
MAP sensor.......i guess
Old Aug 7, 2005 | 04:31 AM
HobieKopek's Avatar
There's a MAP sensor. Bertune nailed it. It sits on the intake plenum.
Old Aug 7, 2005 | 04:50 AM
MalibuJack's Avatar
The map sensor actually isn't really how it tells.. its the MAF sensor and the curve.. the ECU expects a particular MAF Hz (Airflow) reading at particular RPM's and load, if the MAF value is higher than its max reading for a particular RPM, it throws an overboost code.
I think the MAP sensor on our cars is only used under vacuum, its a 1 bar sensor as far as I can tell and doesnt read high enough to tell if the car is in normal boost, let alone overboost.
PearlWhiteX
May 9, 2016 08:05 PM
jay5565
Apr 27, 2015 11:51 AM
08ev
Nov 14, 2013 04:51 AM
rudy91889
Jun 4, 2009 02:52 PM
Celica2EVO
Nov 6, 2007 08:41 PM
