Nisei Mini Battery
Nisei Mini Battery
I was thinking of getting the mini battery kit. Has anyone have any problem with it.
I don't want to have any issue if I am going for few hundred miles trip. Any input is appreciated
Is there supposed to be a downside with using such a small battery? I believe these batteries are designed for motorcycles and are only rated at around 20amperes instead of the usual > 60amperes used by most cars...will these low ampere batteries be overcharged by the alternator and have a reduced lifespan?
Originally Posted by Compjoc
The mini battery kits are known to have difficulty turning over the engine in cold weather.
Originally Posted by Monkey
Depends on the amount of Cold Cranking Amps the battery has.
The BR batter has 1/3 more cranking power than the stock battery. But the battery life isnt much. Antything over 15 minutes is probably pussing it. There are no problems with a smaller battery as long as you dont have a huge system in the trunk or anything.
I use the odyssey batteries in my GSX and has a hell of a lot more cold cranking amps than the stock battery ever thought of. Saves a s@#% ton of weight and room.
The only down side is it can't go a long time running your booming radio without the car on.
http://www.odysseybatteries.com/auto.htm
Joey
Joey
Oddyssey is made by Enersys. http://enersys.com/
Is the PC680MJT battery the one we are suppose to be looking at? How much is it?
Joey
Joey
Ive been using the Nisei for about 4 months now and about 4000 miles. Functions exactly the same as stock sized battery, no problems. Wish I woulda bought one sooner! 20lbs off the front of the car and much more engine bay room!
Here is a complete battery kit for $150.
https://www.evolutionm.net/forums/sh...ighlight=nisei
Right now I heard Nisei Engineering is having a sale til the end of the month and all parts ship free!
http://www.norcalevo.net/forums/view...180c1ef031b0e8
I bought the Enersys Genensis battery from Nisei for $80 (cheapest I found) and I had the tray. But, I'm thinking about getting the tray because of the sale.
Heres the battery I got & the tray I'm probably going to get.
Vibrant
Oct 29, 2008 06:07 PM
