Tapping noise after cam install
Old Aug 8, 2005 | 11:23 AM
Curt@MrLed's Avatar
Former Vendor
as far as i saw tim say it will take a couple of minutes.. shop manual says to vary rpm, from idle to 3500 rpm, till the ticking stops... i havent changed my cams yet so thats all i got for ya..
Old Aug 8, 2005 | 11:28 AM
GOKOU's Avatar
Just curious but do you hear the lifter noise everytime you start the car when it's cold or is it gone now?
After the 272/272 install my lifters were quite and then one day after an oil change I started to hear the lifter noise and heard it ever since during start-up.
Old Aug 8, 2005 | 11:32 AM
anjapower's Avatar
I just put mine in last night. I'm not sure...all I know is that the tick was loud enough at the first start to be heard inside the cabin. This morning when I started it to come to work, I couldn't hear anything.
This afternoon when I started it at lunch to hear the idle , it was fine once again
Old Aug 8, 2005 | 11:36 AM
GOKOU's Avatar
Mines are loud enough to be heard inside the cabin too. This happens during a cold start-up and the lifter noise would go away minutes later. Like I said weird thing was that it started after an oil change
Old Aug 8, 2005 | 11:52 AM
992gnt's Avatar
Mine make no noise at all - cold or warm. If you have one that is noisy only on start up it may have collapsed and needs to be replaced. Not sure what role the oil change would have unless you changed weights or something.
Old Aug 8, 2005 | 12:02 PM
GOKOU's Avatar
Collapsed? Can you elaborate more? Does this mean I need new cams or just need to check for something?
Old Aug 8, 2005 | 12:05 PM
Curt@MrLed's Avatar
Former Vendor
collapsed lifter.. constantly ticks, wont pump up, needs replacing..
Old Aug 8, 2005 | 12:10 PM
992gnt's Avatar
Well the lifter can pump up (sometimes), but will bleed off pressure when the engine is not running. Then every time you have a cold start up it ticks until it pumps up again.
Old Aug 8, 2005 | 12:13 PM
Thegame's Avatar
this is the most intelligent thread i've read in a long time.
Old Aug 8, 2005 | 12:15 PM
mifesto's Avatar
i remember reading about the "italian" lifter breakin to prevent the ticking after cam installation, you drive up to 5-6k rpms and drive it around for a few minutes a few times in between cool-down.... i know its funny but its what i read... only if i remember where i read it from.
Old Aug 8, 2005 | 12:17 PM
GOKOU's Avatar
I'm getting paranoid! So do I need to change the lifters out, cams out, or what . Car seems to run fine and noise decreases as the car gets to temperature
Old Aug 15, 2005 | 06:41 AM
GOKOU's Avatar
Anyone else having lifter noise and potentially collapsed lifters?
Old Aug 15, 2005 | 07:45 AM
matt55's Avatar
I might have had a collapsed lifter , I DID NOT bleed mine down when the cams went in , they ticked-alot . So insted of bleeding the stocker and maybe have 1 or 2 lifters f-ed up (collapsed) I just got some "new" lifters ,took the stocker out , bleed the new ones , put them in and the ticking is much better ! Now it just sound like a stock 4g63 ticking now (ie maybe 1 lifter is ticking ever now and then vs befor all 16 rasing h3ll)
BTW here is the link where i got them form
http://cgi.ebay.com/ebaymotors/16-La...spagenameZWD1V
Zudane
Lancer Troubleshooting
Jul 27, 2012 02:29 AM
silverevo05
Oct 30, 2010 03:34 PM
migs647
Aug 21, 2010 06:31 AM
nonschlont
Jan 13, 2009 07:50 AM
Ultor
May 21, 2004 09:06 AM
