Odd INTERMITTENT tapping Noise !?
Old Oct 28, 2010 | 03:54 PM
silverevo05's Avatar
I know this car makes lots of noises but this one is intermittent, has NO rythm to it and somewhat loud, tapping noise. It went away after a while and seems to be comming from near the timing / drive belt area.
It has 50k plus miles and hasnt made this noise in months since i've had it
06 IX
IVE SEARCHED but most were about lifters rythmic tapping
I will be taking it to the dealer but if anyone knows where to look, or what it might be, I will pass it on to the dealer
Old Oct 28, 2010 | 07:24 PM
Anyone?
Old Oct 28, 2010 | 10:59 PM
white_evo27's Avatar
i would check the lifters... i had this noise also, it went away after running 20-50 royal purple for around 1000 miles... went back to 10-40 and this happened... https://www.evolutionm.net/forums/ev...22186-bad.html
Old Oct 29, 2010 | 03:04 PM
I will have to check that.
its on mobil 1 right now
Old Oct 29, 2010 | 03:25 PM
meckert's Avatar
HMMM, would have to think about it--in order to do it you would have to over rev your motor and float the valve, collapsing the lifter thus dumping the rocker..
Nahhh that can't be a bad thing.
Old Oct 29, 2010 | 03:52 PM
yeh thats pretty much what happened... i didnt think it was that bad either
Old Oct 29, 2010 | 04:04 PM
meckert's Avatar
Talking
LOL, at least you admit it. Thats the first sign of recovery.
Old Oct 29, 2010 | 04:10 PM
i was seriously bummed for about a day... now i joke about it all the time
Old Oct 29, 2010 | 04:34 PM
everything is stock though and it has not been overeved at all
WTF is this noise? Starts about 2 min after warmup and seems to go away after 20 min of driving
Old Oct 29, 2010 | 06:37 PM
i would just pull your valve cover and check
Old Oct 29, 2010 | 07:18 PM
well it's going to the dealer, just want to know if anyone has an idea so I can direct the mechanic. I used a stethescope and cant hear it
Old Oct 30, 2010 | 01:19 PM
gsrboi80's Avatar
Common issues with the IX. See link below. It's even a sticky i the Engine/Turbo/Drivetrain section. I linked you right to page 36 where the issue is outlined in red.
May or may not be the issue ut it's certainly worth a look
https://www.evolutionm.net/forums/ev...-video-36.html
Old Oct 30, 2010 | 03:34 PM
ziyouren's Avatar
check your downpipe, it could be your gasket between the turbo and downpipe. I had the same symptoms before.
blueprint
Aug 19, 2014 05:17 PM
8UpUrV8
Apr 7, 2012 08:00 PM
mink
Lancer Troubleshooting
Aug 1, 2011 11:02 PM
rmrEVO
11
May 23, 2011 09:18 PM
troe666
10
Sep 5, 2006 01:01 AM
