stock cams with custom grind
Old Aug 11, 2005 | 11:19 AM
jxn evo 8's Avatar
I was thinking about taking a set of stock cams out and taking them to a shop to have them custom grinded. Has anyone done this? the reason I am considering this is because the stock cams are great pieces. They are forged and also have hollow shafts. From what I have read, all aftermarket cams are forged so they are not as high a quality as the stock units. Just throwing it out there to see what you all think. It is also cheaper to have my cams custom grinded. IT is only going to cost $300.
Old Aug 11, 2005 | 11:22 AM
mike1023's Avatar
humm.. what do the stock cams need to get done grinded like cut **** off i thought you want the lift to be bigger then the stock ones. or is that the other way the better cams have less of a lift. which is it. and ya if they work well and can handle the power as the others then i dont see why not.
Old Aug 11, 2005 | 11:24 AM
Chris@nolimitmotors's Avatar
I'd just get HKS, For another 250$ its worth it. Stock regrinds just dont sound like a good idea to me. So many people are having good results with HKS, why not just do that?
jxn evo 8's Avatar
not really sure. I
Old Aug 11, 2005 | 01:36 PM
wingless's Avatar
GROUND is the past tense of "grind".
GSC has good HKS copies fer cheap... I woudn't bother.
Old Aug 11, 2005 | 02:39 PM
jesterEVO's Avatar
go hks 272's you won't regret
Old Aug 11, 2005 | 04:01 PM
jxn evo 8's Avatar
thanks for the imput
Old Aug 11, 2005 | 04:04 PM
TEXSRT4's Avatar
forging is better than welding extra slag onto your stockers, then regrinding them. belive it or not, there is a lot more to cams than just having the same duration and lift! 2 companies can make cams with identical lift and duration, but one can make 10-20hp more! it all has to do with ramp rates, overall lift, total duration, etc. go with a proven setup! unless you have lots of time/money to spend
YIfuEVO
Jan 26, 2017 06:44 AM
Royal Evo
Mar 14, 2016 03:51 PM
WartheSecond
Lancer Tranny/Drivetrain Tech
Jun 15, 2015 05:48 AM
mitsuevo803
22
Sep 30, 2010 12:50 PM
evoinit
15
Oct 30, 2004 07:31 PM
