Coolant bypass on throttle body?
Old Dec 23, 2005 | 04:29 PM
  #76
BURNALL_4's Avatar
ya its very easy to do just disconnect the 2 lines use the old clamps get a coupler and connect them together 15 min tops (counting the trip to advance auto parts) sry it's where i work, gotta repersent.
Old Dec 23, 2005 | 04:39 PM
  #77
C6C6CH3vo's Avatar
A coupler would be easiest but I just yanked the short hose out and connected the end of the long hose (still attached at the block) to where the short was attached (on engine). I used the existing clamps.
A little tougher to access the connection but it's cleaner
Old Dec 24, 2005 | 08:13 AM
  #78
Creamo3's Avatar
That's the easiest and "free" way of doing it. Plus you can just reverse it if you want to.
Old Dec 24, 2005 | 08:36 AM
  #79
taenaive's Avatar
Originally Posted by superz
If you think that the coolant at about 185 degrees is actually going to affect the intake manifold as far as getting it hotter you are wrong. The intake manifold gets way hotter than 185 degrees, this from being bolted to a head that is bolted to a super hot turbo manifold. So if you guys suspect that coolant running through the TB will actually heat it up you are mistaking. The reason race cars eliminate this is purely due to having one less leak to possibly worry about, or because their bigger TB doesnt use coolant passages.
what a miss info. we are talking about the throttle body on intake mani here. the throttle body sees around 100F only.
TEXAS TRAVISTY
Outlander Sport
10
Nov 24, 2023 03:27 PM
evo@24psi
12
Jun 7, 2009 10:37 AM
crypto
Lancer Engine Tech
12
Dec 21, 2007 07:05 AM
atilla
Lancer How Tos / Installations
May 3, 2007 10:18 AM
dryad001
Feb 20, 2004 09:42 AM
