Throttle Body Coolant By-Pass???
Old Jan 10, 2009 | 12:35 AM
evo@24psi's Avatar
Aight guys, I thought i blew my motor tonight toying around with some friends. Smoke and steam was everywhere!!! Come to find out i just split one of the coolant hoses from the Throttle Body to the block. Lost over a gallon of Antifreeze. Well there was a few LS-1, LT-1, and Mustang guys there and they just told me to By-pass it. So i did. I was goina replace to split hose but after getting home and them showing dyno graphs of Camaro's and Transams gaining upwards of 7-10whp from this by-pass im thinking bout leaving it this way. Not like i EVER need to worry about the "freezing" temps in Biloxi, Mississippi. Has anyone else on here done this? Any side affects besides a cooler Throttle Body and more power lol? Thankx in advance!!!
Old Jan 10, 2009 | 12:58 AM
cpoevo's Avatar
People do it in SoCal and I havent heard of any problems, but I havent seen any dyno comparisons either
Old Jan 10, 2009 | 06:54 PM
evo@24psi's Avatar
Anyone else??? Car actually seems to idle ALOTT better today after the by-pass.
Old Jan 10, 2009 | 09:52 PM
tookinkee's Avatar
I do believe the Skunk2 throttle bottle bypasses the stock coolant path.
Old Jan 10, 2009 | 11:29 PM
Broxma's Avatar
Doing this little "Mod" is as old as the 4g63 itself. We did this as one of the first "Free Mods" back when DSM's were baby young. Almost all cars run coolant through the TB. I would think an NA car would see a higher gain from it rather than a blown car though.
Did it make any power? Dunno. I don't know if anyone ever bothered to dyno it. It makes sense that it might but how much is probably less than a small change in atmospheric settings on the dyno.
Is it safe? It is effectively an emissions device, heating the intake air at cold temps. Is it safe to remove your cat or safe to block off the EGR? Sure. Your bypassing it, not blocking it off. Even if you did block it off, it would most likely still be safe as the dead water in the blocked off hoses would be insignificant in the grand scheme of the cooling system.
/brox
Old Jan 22, 2009 | 01:50 PM
joseph k's Avatar
does it make power? no
does it allow for more power to be made through cooler IAT's absolutely.
we do this on almost every car we get into the shop. like you stated we do not have to worry much about the ambient temps here getting too cold. which has kinda bitten us in the *** this week
Old Jan 27, 2009 | 07:33 PM
atkins's Avatar
just bought a skunk 2 68mm t/b, they are eliminating the coolant lines from the gate with their t/b's. i dont htink it will make to much power but it definately wont rob any.
Old Jan 28, 2009 | 04:32 AM
Tigre's Avatar
old mod nothing new. coolant helps cold temp guys warm up the TB quicker thats about it
Old Jun 4, 2009 | 12:58 AM
TTVR-4's Avatar
back from the dead.. but why would mitsu even put coolant through the throttle body if it does nothing?
Old Jun 4, 2009 | 07:22 AM
joseph k's Avatar
it's not like they are the only company that does it. and it does do something
Old Jun 4, 2009 | 12:41 PM
TTVR-4's Avatar
nevermind .. was tired just read this lol
Old Jun 4, 2009 | 07:48 PM
mrboost05's Avatar
just about every car i ever worked on has had it ran thru just another thing they do it also keeps the throttle from sticking untill things were warmed up on some of the honda motors i did this to they had a high idle for a bit but nothing crazy good free mod .
Old Jun 7, 2009 | 10:37 AM
Monochrome's Avatar
High idle while the motor is warming up.
blew_by_u
Lancer Troubleshooting
Jul 22, 2016 09:22 AM
02-Lancer-Es
Lancer Engine Tech
25
Oct 14, 2007 04:07 PM
atilla
Lancer How Tos / Installations
May 3, 2007 10:18 AM
dryad001
Feb 20, 2004 09:42 AM
EgoBuSTeR
Oct 29, 2003 03:59 PM
