Q. for those using the gm boost solenoid
Old Aug 25, 2005 | 07:05 AM
EvoTech's Avatar
Originally Posted by johnjonfenomeno
Where can I order a Gm boost solenoid and how much and where can I get the Perrin and how much?
Talk to Adam at Z1. He can hook you up with the Perrin.
Old Aug 25, 2005 | 08:40 AM
USP45's Avatar
Gm part #'s are 1997152 for the solenoid and 12102747 for the harness @ gmpartsdirect.com and I think that it is around $30 shipped for both. The harness is more expensive then the solenoid......go figure.
Old Aug 25, 2005 | 05:28 PM
johnjonfenomeno's Avatar
does the perrin need a harness or anything to make it work or is it a direct plug and play?
Old Aug 25, 2005 | 05:34 PM
nothere's Avatar
the perrin comes with about three feet of leads. you will need to trim them down to the length you want and connect them somehow to the stock plug// or cut the plug off and simply conect the wires.
I don't know of anyone who sells the stock plug mate. so you either rig up something to the plug or wack it off.
so you would have the same condition with the GM solenoid, you can get a plug for it, but the side that connects to your car is as the perrin .....wires.
Evo_Jay
Nov 1, 2018 10:01 AM
RS200
Jan 23, 2016 04:19 PM
mchuang
Apr 21, 2013 12:58 PM
rolly1818
May 8, 2010 03:14 AM
sba
Apr 8, 2008 05:07 PM
