Replaced Plugs now po300 code
Old Sep 4, 2005 | 07:12 AM
BoostWhore's Avatar
I just replaced plugs with ngkbr7ix I know there the iriduims i think i may have the #st here wrong anyhow. I have never had the misfire code. I did not gap the plugs b/ it says not to. Im currently @ 320whp. Funny thing is my code came on when i had been sitting in a parking lot for an hour idling. NO poblems throughout the powerband maybe just idling after so long caused this.
Old Sep 4, 2005 | 07:28 AM
mobounce's Avatar
It's an 03...its bound to happen...search on p0300...its virtually un-fixable. Even after dealer reflashes, problem will still persist. Sorry man, don't mean to be the negative one. For some it gives no problems whatsoever...for me, it made the car virtually un-driveable after awhile because of sputtering and severe random lean conditions. I am now an AEM EMS man because of it....which is nice, don't get me wrong
Old Sep 4, 2005 | 07:38 AM
Zeus's Avatar
I've never had those problems on either Works or Turbo Trix flashes in my 03'... You might want to look into a flash if your problem persists.
First though, I'd check the gap on the plugs... it doesn't matter if "those plugs are not supposed to be gapped". If they are not gapped low enough, they are not gapped low enough. Just don't screw them up.
Old Sep 4, 2005 | 07:40 AM
PVD04's Avatar
I got the PO300 Code after installing BR8ES plugs in my car. I tightened the gap to 0.024 and haven't had the problem since.
-Paul
Old Sep 4, 2005 | 07:49 AM
Zeus's Avatar
That's my recommendation...
Old Sep 4, 2005 | 10:57 AM
k270kmh's Avatar
Why didn't you buy the NGK bPr7eix?
Old Sep 4, 2005 | 12:23 PM
BoostWhore's Avatar
that is the plugs i bought i just couldnt remember the # when i was typing this. What gap should I make sure there at .24? thanks
Old Sep 4, 2005 | 02:44 PM
k270kmh's Avatar
BPR7EIX - P = Projected insulator = Same as stock
BR7EIX - Non projected insulator = a little bit colder, like a 7.5 - Correct me if I'm wrong.
I'm with NGKBPR7EIX without any problem.
Old Sep 4, 2005 | 02:51 PM
k270kmh's Avatar
BTW, give a try to the NGKBPR8EIX since you have more than 70 crank hp over stock.
X2jesse1x
Aug 8, 2017 05:51 PM
mitsuman06
Sep 17, 2013 06:07 PM
jenapher928
Lancer Troubleshooting
Sep 10, 2012 02:05 PM
fwd_josh
Jan 23, 2010 09:54 AM
drewblueeye
Dec 10, 2006 08:19 PM
