first mods to do?
Old Jan 28, 2002 | 06:46 AM
japspec4g63's Avatar
first mods to do?
Guys, please help me! I'm getting an evo V real soon but I live in the US. I already have an intake, exhaust, and boost controller. I heard to be safe, I shouldn't go higher than 1.2 bars. I was wondering what would be the first mods to do to my evo. I heard that I really want performance, I need a remapped ecu and fuel stuff. I was wondering what one would suggest for the first couple of mods for my evo. I live in the states too. thanks!
Old Jan 28, 2002 | 06:50 AM
Hooby's Avatar
I've heard a nie way to get more performance not to mention a longer engine life is replacing the engine internals.
I'm not massively informative on the engine aspects, so somebody tell me if I'm an idiot er not.
Hooby
Old Jan 28, 2002 | 04:31 PM
Maxi's Avatar
you need to see if your exhaust is complete, for example turbo elbow,downpipe, decat pie, mid section and rear muffler like the hks extension kit and hyper muffler, and if the air filter is an induction kit as hks rs kit or blitz.
After that, you can fit a new ecu. The ralliart sports ecu works well but it's made to be used with good fuel, around 98ron and with free flow exhaust and filter. It's a good deal if you can get it at the japanese price, at around 1000$. If it cost more than that you can buy better stuff like gems in uk, or go for another ecu like mine's or blitz.
These kind of setup will allow you to run 1.4bars without fuel cut and giving the right fuel.
Old Jan 29, 2002 | 08:24 AM
Billy's Avatar
This is on TME's only or on all 6's?
Will the stock injectors and fuel delivery system find this practice to be acceptable behaviour?
Old Jan 30, 2002 | 09:30 AM
since I live in the states, where can I get parts? does anyone have any good connections? also, 93 octane is the highest pump gas I have available to me. is there any way they can program my ecu for that? please help! thanks!
Old Jan 30, 2002 | 08:03 PM
KK's Avatar
KK
EvoM Administrator
japspec4g63, look into getting an Apexi Power FC with controller. It's very easy to tune, but is a full ECU replacement so you can enter the maps for timing, fuel, boost, etc. I know someone who is extremely reliable and should be able to get you a unit. My guess is that price would be around $1300 or so. Here's his website:
http://godspeed.hack.net
Another place that may be able to get them is rx7-store.net:
http://www.rx7store.net/powerfc.htm
Curry's Auto in Sterling, VA has an AWD dyno as well as Altered Atmosphere in Gaithersburg, MD.
Mark
Old Jan 30, 2002 | 08:54 PM
FoxVR6's Avatar
Re: first mods to do?
Hey man, are you buying the one that was on ebay a little while back? I think I remember it being in Virginia. Anyway, should make or one sweet ride
Old Jan 31, 2002 | 03:37 AM
JaffaKaffafa's Avatar
Internals
I recommend replacing the ARP bolts first to ensure that the conrod doesn't separarte from its big end cap as you search for increased RPM and boost. You can then increase boost to around 1.3 bar before strengthened conrods are needed. With this done put a freer flowing exhaust and induction system in place and use a reprogrammed ECU to handle the increased airflow and fueling - Stage 1 (300+BHP).
A strengthened crank, thrust bearing, forged pistons and conrods will permit you to run the engine harder still. However, you'll not see the full benefits without further developing the exhaust, induction, fuel delivery and ECU. Extra BHP can be achieved by gas-flowing the head, and polishing the ports, induction manifold and exhaust manifold. Larger injectors and higher capacity fuel pump are required for higher states of tune. Also check you're running the correct density spark plugs. BR7 is fine for normal states of tune but faster running requires BR8 or BR9 for high states of tune.
Fully bored out to a combined capacity of 2.3L, equipped with a bigger turbo, a competition manifold, a Group A steel crank, forged pistons and conrods, full anti-lag system, bigger fuel pump and injectors, Motec or Gems tuned ECU, competition exhaust and other mods, 500+bhp and 460+lbft is possible. Not for the shopping though.
Summary:
1. ARP bolts.
2. Exhaust, Induction & ECU (upto 1.3bar - brakes? AP 6pot 332mm?).
3. Strengthened crank, thrust bearings, forged pistons and conrods, uprated dump-valve, uprated standard clutch or single plate cerametallic paddle clutch, and EvoVI intercooler, or other + freer flowing boost pipe (upto 1.4bar).
4. Boost and fuel controllers - e.g. Apexi AVC-R and Super AFC - multi-plate clutch, and modified inlet & exhaust cams (upto 1.6 bar).
5. Consult a specialist if you require any further mods (you nutter ).
Have a look here.....
http://www.tdi-plc.com/LANCER.html
Old Jan 31, 2002 | 09:43 AM
no, I didn't buy it in VA. I was trying to sell my evo IV conversion, I think that's what you're thinking of. anyways, someone was selling it as a track car and I got lucky! thanks for all your help guys! how much hp are stock internals capable of handling safely? thanks!
Old Jan 31, 2002 | 02:51 PM
Michaelk's Avatar
Ths pistons on 5s are different than 6s so I don't know if they can take as much boost as a 6. A 6 can live with 1.6 bar, some say you need to replace the conrod bolts, some say you don't. Either way, have never heard of a bigend failure on a 6, so that kinda favours the last group. Don't go buying a cerametallic clutch though, unless you go for silly HP, otherwise an AP organic clutch will take up to 400bhp.
Old Jan 31, 2002 | 02:56 PM
You need to replace the ARP bolts before doing anything! With this done, aim for 330-350bhp at 1.3bar before the other internal mods are required. Have a look at a highly tuned one below.....
http://www.junauto.co.jp/democar/evo5/spec.html?en
JUN have a US branch, the search found the website below but it wouldn't load for me. Maybe you'll have better luck being in the US.
http://www.junusa.com
Old Jan 31, 2002 | 07:31 PM
I love this forum. thanks guys, you guys are very helpful. I'm still a newbie to real evos, even though I've been following them since 98. let's talk about price. how much would a set of ARP bolts cost? what would you do with a $2000 budget? and how much hp gain could I get with this? same question for a $3000 budget. and same for a $4000. I was just wondering what you guys would do on these budgets and how much gains you would get. thanks! (don't include labor prices)
Old Feb 1, 2002 | 12:30 AM
Have a look at these prices.....
Prices are in £s and may vary from UK to US anway.
$2000
___________________________________________
ARP bolts - ~£200
Exhausts ~£500-600 (Beware noise level legislation local to you)
HKS Super Dragger OR
HKS Hyper Muffler OR
Blitz NUR Spec R
Induction
HKS Racing Suction air filter kit ~£300 OR
HKS Super Power Flow air filter kit ~£200 OR
Blitz Sus air filter induction kit ~£200
Dump Valve
HKS Sequential Blow off Valve ~£250
Blitz Dump Valve Kit £250 ________________________________________
$4000+
Uprated Head Gasket ~£200
HKS Iridium Spark Plugs ~£50
HKS inlet and exhaust cams ~£600
Performance alloy intercooler kit ~£700
HKS intercooler piping kit ~£400
HKS turbo timer and wiring harness ~£100
HKS EVC 4 boost upgrade kit ~£500 (upto 1.3 bar)
HKS F-CON V ECU and wiring harnesses ~ £1000 (ow! But you can select what 'RON' fuel you are using - don't like the sounds of this 93 RON fuel though, you won't get the same power)
Doing things right is expensive but so is a knackered engine.
http://www.hksusa.com
Old Feb 1, 2002 | 03:44 PM
Michaelk's Avatar
Jaffa,
how can you say that the big end bolts need to be done for ANY boost going above standard. There are many 1.5 bar Lancers out there that have no problems whatsoever. Or do you have an example of an Evo on which the big-end bolts failed (running less than 1.6)? I would be very interested to hear about that.
And how exactly are you looking to extract 350 bhp at 1.3 bar, assuming that you're using tha standard turbo?? 330 is realistic but 350... would love to see that.
