People who use meth, what kind?
Old Sep 12, 2005 | 09:01 AM
GOKOU's Avatar
Originally Posted by dryad001
Well I found some not far from my house for $1.87/gallon. And this is race methanol, at least this is what the guy on the phone told me.
Dang that's not bad at all. I need to find some place near Palatine\Schamburg IL area that sells methanol. I believe AMS sells it for $6/gallon $30 for 5 gallon drum. Dang 100% methanol or denature alky????? shoot!!!!
Do you guys search for places that sell 100% methanol in that area before going out of town???
Old Sep 12, 2005 | 09:11 AM
dryad001's Avatar
The price was for 100% meth. If you ever head up to the SE WI part of town look up a place called EH Wolf in Slinger.
Old Sep 12, 2005 | 09:13 AM
4G63>OOOO's Avatar
$1.87 sounds about right for VP Racing M1 Methanol.
Old Sep 12, 2005 | 09:17 AM
GOKOU's Avatar
Cool ! I drive up that way going to Appleton, WI.
I believe the $6 per gallon from AMS is 100% methanol. Or was it racing fuel and I got confuse
http://www.slingersuperspeedway.com
Old Sep 12, 2005 | 09:48 AM
djh's Avatar
djh
Originally Posted by blazedevo781
HOME DEPOT painting section....denatured alcohol
Just be aware that denatured alcohol is ethyl alcohol, not methyl. Also "denatured" is a legal term, not a chemical term. There are around 20 or more legal formulations of denatured alcohol so you have no idea of what else is in there -- some have dissolved solids. But most of them are probably OK unless you're running so much alcohol that you're using it as a substitute fuel rather than just a boost fluid.
Dave
Old Sep 12, 2005 | 12:51 PM
SlowCar's Avatar
Denatured alcohol = ethyl alcohol + methanol + other fouling agents like mek, acetone.....to make it undrinkable
HOME DEPOT painting section....denatured alcohol.....great stuff....decrease possibility of detonation while cooling....i use it with my SMC injection system
Old Sep 12, 2005 | 01:07 PM
Ted B's Avatar
99+% Methanol can be had by the 55-gallon drum from any local industrial chemical supplier. I just purchased a drum at $2.47/gallon, which is cheaper than pump gasoline at this point in time. They'll usually even deliver it.
You will need to go to Grainger supply or equiv. and get a bung tool and a cheapie ($10) poly drum pump. Dispense 5 gallons at a time into a suitable container and keep in your trunk.
Old Sep 12, 2005 | 01:31 PM
GOKOU's Avatar
I thought 100% ethanol was flammable so keep it in the trunk is a no no correct? Also what's the storage temp? Damn I need to do more research on methanol before buying
Old Sep 12, 2005 | 01:43 PM
Ted B's Avatar
Methanol is flammable, but so is gasoline. If there is some federal reg that prohibits carrying fuel in an approved container in the trunk, that's news to me.
Yaroslav's Avatar
Exclamation
AGREE!
Very danger
Old Sep 12, 2005 | 02:01 PM
Evoryder's Avatar
methanol is highly flammable...you should make sure your kit has no leaks...teflon tape threads...if it catches fire...by the time you notice...it will be too late.
Old Sep 12, 2005 | 02:07 PM
Doogie Howser's Avatar
What exactly do people who use SMC alky kits use? 100% methanol?
Old Sep 12, 2005 | 02:13 PM
Yaroslav's Avatar
Exclamation
No. For your safety you can use 50/50 water/meth
but less power. And it feels so strong
Old Sep 12, 2005 | 02:48 PM
inco9nito99's Avatar
Torco Racing 100% Methanol. ~750cc of this stuff at 20psi
ps. 100% Methanol is completely safe and will produce the most hp. If you're worried about flamability, methanol is less combustive than gasoline.
billsIXmr
Northeast Region
18
Feb 26, 2016 08:59 AM
playafly
29
Jul 18, 2008 09:08 AM
steadly2004
Jan 4, 2008 05:00 AM
SlowCar
Nov 29, 2007 06:48 PM
evoixpr
Nov 26, 2007 12:24 PM
