Best Intake for the 05 Evo?
Old Sep 12, 2005 | 11:15 PM
MLCksysio's Avatar
I got my evo around a month ago and i thought of putting some parts on it. First i wanted to put an intake on. For those of you that have them, which intake do you think give the best numbers for the evo.. best numbers that have been proven?
I would appreciate some answers. Thanx you!
Old Sep 12, 2005 | 11:17 PM
eling99's Avatar
i have a k&n drop filter.....but im thinking bout changing to a works drop in filter
Old Sep 12, 2005 | 11:18 PM
Curt@MrLed's Avatar
Former Vendor
they all pretty much give you the same, just cost different.. but a intake will not give a big advantage till you get tuned, cause it will cause the m.a.f. to get the wrong readings.. and that needs to adj.
Old Sep 12, 2005 | 11:21 PM
MLCksysio's Avatar
I saw the AEM Intake, and also the one Eling99 mentioned by K&N.
Old Sep 12, 2005 | 11:36 PM
nj1266's Avatar
I wish you would do a search before asking questions that have been asnwered a billion times. As you were told above, an open filter intake on the EVO w/o a re-flash of the ECU or a piggy back ECU or a standalone tune will make you LOSE power. The MAF will get erratic readings probably because of the proximity of the MAF to the open element filter. So stay stock or simply get a drop in filter.
Old Sep 12, 2005 | 11:38 PM
2hot2handle's Avatar
theres a lot of opinions on what "the BEST intake" is, but for the most part a full intake replacement ( charge pipe w/ open filter) will achieve about the same hp. same goes for a drop in. A TUNE will help the most. of course if your looking for the "sound" then an open element filter will be louder. (HKS RS, AEM, HELIX) but some people have had problems w/ open element filters. (throwing off MAF) but thats just SOME people. others will suggest to stay w/ the stock air box and just add a drop in filter. (hks, works, k&n) "sound" will not be as loud but performance is still good. havent heard of a problem from anyone w/ just a drop in. and theres the "in between" which a lot of people also have done w/ no problems reported whatsoever. Change the intake charge pipe to something like the HKS RS but keep the stock airbox w/ a nice drop in filter. theres a couple companys that make a replica of the HKS charge pipe and you can bolt it up to the OEM air box......hopefully this should save a lot of people arguing over what is "better" oh and i forgot, some people will suggest "stick with the stock air box period"
Old Sep 13, 2005 | 09:37 AM
Ludikraut's Avatar
Keep the stock intake, just get a drop-in filter. Save your $$ for better mods.
l8r)
Old Sep 13, 2005 | 09:42 AM
Chris@nolimitmotors's Avatar
I like the injen alot, I have it and def noticed an increase in power.
Old Sep 13, 2005 | 05:49 PM
Jakeg97's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=147111
Tizart69
Apr 24, 2010 08:57 AM
love67
35
Jul 29, 2009 01:37 PM
filter
Sep 24, 2006 05:00 PM
TurboMR
26
Dec 22, 2005 11:42 PM
skidd12
20
Oct 24, 2002 06:37 PM
