Quickie Oil change question.
Old Mar 8, 2003 | 10:54 PM
gtr's Avatar
gtr
After draining is it safe to dry crank the motor on a turbocharged car to get the oil from the valvetrain out? I remember shade tree mechanic did that on their oil change and then again that's a push rod engine
Better ideal just wait and drain to get most out? For the evo owners, how many quarts do you fill?
4.5L?
thanks,
Old Mar 14, 2003 | 08:44 AM
stanfosd's Avatar
I would never recommend dry cranking the engine.
You are risking destroying your bearings at the cost of trying to get a little more dirty oil out of your engine. Definately not worth it. Just make sure to use a good quality oil, preferably synthetic and a good oil filter and all will be fine. I always recommend synthetic oil on a turbocharged car because the oil is put under a lot more stress from the increased heat.
Old Mar 14, 2003 | 09:23 AM
rooster's Avatar
just let it sit for an hour prior to draining, 99% of the oil will drain.
Old Mar 18, 2003 | 12:05 PM
superz's Avatar
gtr-- Never dry crank your engine! Oil is needed between main and rod bearings, otherwise you will destroy them within seconds.
The best way to drain the oil is when hot. Go for a hard drive and the oil will drain out like water, just be carefull0its really hot.
ak47po
33
Mar 21, 2016 11:31 AM
gallas
Jan 10, 2012 05:37 PM
Tagge
22
Dec 3, 2010 07:03 PM
Djstorm100
Jun 29, 2010 01:29 AM
EM1 to EVO
Oct 3, 2008 08:59 PM
