Hallman Pro RX and the stock boost solenoid
Old Sep 21, 2005 | 06:16 AM
avengerhed's Avatar
CLIFFNOTES:
Can I simply make a vacuum line loop around the stock boost solenoid?
For 20 PSI should I be using the heavy spring?
How many turns (approximately) will equal 20PSI?
I'm going to be installing my Pro RX this weekend. I'll be using the Turbo outlet nipple for the reference port and I have a question regarding the stock boost solenoid.
In order to keep the stock appearance, and not bother with vacuum caps, can't I simply connect one port of the stock boost solenoid to the other? I have an aftermarket turbo inlet pipe with a bung for the stock boost solenoid so instead of capping it, i was thinking of simply making a loop of vacuum line and leaving it as-is.
I seriously doubt that this would cause any problems but is there something I'm missing?
In addition, I SHOULD be using the heavy spring in the RX right? My thinking: stock wastegate actuator is set at 12psi, the light spring can only add 5psi, totalling 17. I'd like to get a solid 20, so I figure I should use the heavy spring.
Any clue on how many turns = 20PSI on the Pro RX?
Thanks for your help
Old Sep 21, 2005 | 08:10 AM
dan628's Avatar
I've heard you can make a loop, but I bought some extra caps at autozone.
I used the heavy spring for 20 PSI and it works great.
I have it about 4 1/2 turns....
I hope this helps and good luck!
Old Sep 21, 2005 | 08:58 AM
avengerhed's Avatar
hey dan. thanks for the help. I may just go ahead and pick up some other vacuum caps.
and again, thanks for the insight on the MBC setup!
Mellon Racing
Vendor Classifieds
406
May 24, 2013 05:53 PM
evo jason
Jan 31, 2012 11:47 PM
TURBevO8
11
Aug 24, 2006 08:49 AM
JSYEVO
17
Aug 17, 2005 05:26 AM
tequila083
Feb 13, 2005 03:00 PM
