EVO VIII Dyno Results
Old Mar 12, 2003 | 12:04 PM
  #31
ScoobyDoobieSTi's Avatar
Originally posted by AMS
We have a WRX wagon and the EVO will kill the wagon in straight line acceleration even with the WRX having 3" turbo back exhaust, MBC at 16psi and a UTEC.
Martin
I thought Dylan left AMS way before the evo came out. He claimed that he ran 13 flat with those mods.
Old Mar 12, 2003 | 05:16 PM
  #32
DSMBRETT's Avatar
We also dynoed the car with 93 Ocatne gas and it made 188 wheel horsepower. That is still lower than we would expect to make on a 271 horsepower rated car. The car did run noticeably better with the 93 octane and felt somoother as well.
Brett Payne
Vishnu Performance.
Old Mar 12, 2003 | 10:53 PM
  #33
Van's Avatar
Van
Wow this place flames up quick eh?! Hehe.
I read both threads about the EVO8's apparent hp levels on the dyno. Interesting to say the least. It seems that the one dyno reads low for everything, based on what I've always seen.
Really though, EVO8's are already posting mid 13's at the track. Sweet as that's what really matters. I suppose nobody here has ever seen a dyno queen do jack at the track.
One thing I do know is time will tell. I predict the EVO8 will be posting mid to low 13 sec ET's everywhere. Just as soon as the season begins. It'll be an eye opener for some, hehe.
I can't wait until a few of the tried and true DSM shops, like AMS, Buschur, Magnus, FP, etc. start fabbing parts for them.
It's all good.
Old Mar 13, 2003 | 08:08 AM
  #34
ShapeGSX's Avatar
Brett Payne
Vishnu Performance.
Did you reset the ECU after putting in the 93 octane but before dynoing? Or at least drive around on 93 octane for a day or so?
DSM ECUs have a long term knock value in them that will cut timing and boost long-term. The ECU will test the octane by upping these values periodically, but it can take a while. Therefore you have to reset the ECU.
Of course, this is on DSMs. I suspect that there is a similar system on the Evo. However, I have no idea if resetting the ECU will reset the ECU back to "good gas" mode. It is always possible that the value is stored in flash in the new ECUs (though I doubt it), which would mean that cutting power to the ECU wouldn't do anything to the stored values.
Old Mar 13, 2003 | 08:38 AM
  #35
favre95's Avatar
I reset the ECU back when I had my talon many times around 9-11-01 when gas went through the roof. I couldn't afford to put premium in so I got stuck with 87 for about 3 weeks. At one point in time even after putting in 101 octane gas in my boost gauge still read 10.5 when I should have been running about 15 on that good of gas. SO....I just took it home after work one night and disconnected the battery for 15 min. AND BANG I was back to 15 psi....yes it does help, yes it will most likely help with the evo...because the boost management system is very very similar to a DSM. I believe that after time these engines will produce the 200-210 whp. One, they need to learn your driving style and two they adapt very fast to crappy gas...such as 91 octane!
Old Mar 13, 2003 | 12:45 PM
  #36
trs94's Avatar
Hmmm...has anyone posted a time slip?
TRS
Old Mar 13, 2003 | 01:08 PM
  #37
vividracing3's Avatar
We dyno tested our EVO last night on a dyno dynamics dyno and it did 230 whp.
Old Mar 13, 2003 | 01:21 PM
  #38
Longfury's Avatar
r u going to redyno it after u talked with Vishnu Performance Systems?
Old Mar 13, 2003 | 01:42 PM
  #39
DSMBRETT's Avatar
We did reset the ecu, and tried a few other tricks as well. Same result.
Brett.
Old Mar 13, 2003 | 01:55 PM
  #40
Longfury's Avatar
i still wanna see what vivid gets after changing things to be more like your configuration Brett
Also...i am sorry about some comments i made earlier...i was having a bad day and hearing everyone grip was not helping...no hard feelings ok
Old Mar 13, 2003 | 04:12 PM
  #41
gtr's Avatar
gtr
DO you know what a stock WRX would run on that same dyno?
Old Mar 14, 2003 | 05:31 PM
  #42
122andy's Avatar
Brett.
Another trick would be turning that knob on your dyno, it will make the HP read higher also.
Old Mar 14, 2003 | 06:01 PM
  #43
A stock wrx puts 166 On that dyno.
Old Dec 10, 2003 | 12:56 AM
  #44
Angel Of Mercy's Avatar
The 300+ horses are due to incorrect dyno settings... i did my 1st dyno using shootout mode 4 (4 cyl 2wd) and got 308hp and 227hp (better accuracy) at wheel whilst the correct one should be about 250+hp at flywheel.... the stock evo7 gets about 210-230hp at the wheel (tested with 2 cars: 1 with airfilter and 1 with airfilter and downpipe back exhaust system)
Read my new thread on dyno results and repost your shoot 44 results there pls...
Old Dec 10, 2003 | 11:50 AM
  #45
ItsStockOfficer's Avatar
Originally posted by nightrider
hmm first there is a post from someone else sayong thier dyno's were to low to post and now we have one with incredible numbers. i dunno but i hope the rest of the dyno's turn out like this guys. if thats the case then im prob gonna try and save and get me an evo one of these days. damn and it amazes me how with just a couple of modifications on a stock evo can produce another 30-50 hp. im not saying i dun believe it. i am jsut dying wanting the car. id anyone in the Colorado area would like to give this poor boy a 10 min ride in their evo it would be greatly appreciated. jsut bored so i posted.
Se, this, ladies and gentlemen, is why you shouldn't take dynos to seriously.
Here they have lots of hP, there they don't have as much....
They still perform the same, it doesn't matter. maybe you would be happier if you bought your evo then immediately moved to Chicago so it had more horsepower.....
recompile
54
Jul 9, 2008 11:18 AM
scheides
24
Jan 26, 2007 03:12 PM
Fourdoor
18
Mar 6, 2004 09:00 PM
Fourdoor
25
Oct 28, 2003 06:50 PM
boiwunder
Automotosports - Illinois
30
Apr 2, 2003 09:16 PM
